20 Most Recent Xerox Phaser 3200MFP/N Laser Printer Questions & Answers
0answers
2answers
LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
5/1/2017 4:12:34 AM • Xerox Phaser... • Answered on May 01, 2017
Install toner and continuously beeping
If you have recently replaced your toner drum then probably the replacment drum is not matching the printer`s criteria or may be the repalcement drum is not the right to be intalled in. Check with service manual if you have got the right replacment or not.
4/25/2017 11:42:15 PM • Xerox Phaser... • Answered on Apr 25, 2017
Xerox phaser 3200 mfp warming up please wait
need change fuser unit
9/9/2016 12:56:17 PM • Xerox Phaser... • Answered on Sep 09, 2016
I have a xerox phaser 3200mfp it keep showing
The fuser is not coming to temperature. Probably bad temperature senor on fuser. Replace fuser.
3/23/2015 3:39:37 AM • Xerox Phaser... • Answered on Mar 23, 2015
2answers
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
3/14/2015 3:58:47 PM • Xerox Phaser... • Answered on Mar 14, 2015
How to refill ink in hp 950?
Take your empty cartridge to any Costco or Fry's electronics and they will fill it for you at a great price www.costcoinkjetrefill.com
8/8/2014 12:09:26 AM • Xerox Phaser... • Answered on Aug 08, 2014
0answers
Printer says LSU error. what does it mean.
Laser Unit has failed and needs replaced.
3/16/2014 5:30:56 AM • Xerox Phaser... • Answered on Mar 16, 2014
Lsu error,before that not this problem on my
I would highly suspect a defective toner. What happens if you put the old toner back in - - do you get the same error? If you don't, then replace the toner. If you continue to get a lsu error, then your Laser Unit has a toner spill on the glass, or has gone bad and will need replaced.
3/16/2014 4:55:50 AM • Xerox Phaser... • Answered on Mar 16, 2014
Open heat error
Open heat error is caused by a bad fuser. Replace the fuser assembly.
3/16/2014 3:50:50 AM • Xerox Phaser... • Answered on Mar 16, 2014
0answers
Install to pc
go to xerox.com driver, put in your operating system type and download the proper driver
1/16/2014 10:58:25 AM • Xerox Phaser... • Answered on Jan 16, 2014
Windows xp3
12/7/2013 3:55:13 PM • Xerox Phaser... • Answered on Dec 07, 2013
Xerox Phaser 3200MFP/N Laser Printer Logo
109 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
install toner continuously beeping
  • Office Equipment & Supplies
