20 Most Recent
Canon PIXMA iP1800 InkJet Printer Questions & Answers
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
My printer is canon pixma
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
I install a new Black
To Head aligment, Its simple, open a document and select print from the menu,
- In the print screen window select 'properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc... which you can do it for your self after reading each descriptions.
Hope this helps, please rate and leave a comment if this solution was helpful, thank you!
