20 Most Recent Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D Questions & Answers
My freezer is making this moaning sound when the
Is it freezing properly to zero degrees F? Noise could be bearing in evaporator fan motor, or compressor itself.
9/14/2017 2:43:36 AM • Frigidaire... • Answered on Sep 14, 2017
0answers
253.9287412
Be the first to answer 12/25/2013 2:16:01 AM • Frigidaire... • Posted on Dec 25, 2013Be the first to answer
My freezer does.not freeze and the hi temp light is on.
Had the same problem, I unplugged freezer for two days, pluged back up, has worked fine since.
3/26/2013 8:27:53 PM • Frigidaire... • Answered on Mar 26, 2013
Freezer is running all the time but everything is frozen
You have a bad t'stat. Can you turn it it upborcdown.
3/1/2013 3:44:20 AM • Frigidaire... • Answered on Mar 01, 2013
Why does my new upright 20 cubic Ft freezer state I can set the temp at 15 and lower to -15 but doesn't state it can be set above 15 degrees
You should be able to set the unit up to 30?F and still freeze some contents.
7/31/2012 6:43:25 PM • Frigidaire... • Answered on Jul 31, 2012
Frigidaire FREEZER LffH2067DW3 stuck in defrost
Turn the unit off by the circuit breaker for about 10 minutes and retry the unit again.
7/24/2012 5:53:52 PM • Frigidaire... • Answered on Jul 24, 2012
Freezer started defrosting and the sides where
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
8/23/2011 1:05:40 PM • Frigidaire... • Answered on Aug 23, 2011
The Temperature alarm is going off. What does
The unit is not at correct temp, ""unsafe to keep food"". Needs service.
Hope that helps. Russ.
If you remove all the items from the unit and defrost it for 2 days with door open, on restart, should work fine..
6/12/2011 10:32:25 AM • Frigidaire... • Answered on Jun 12, 2011
I have a Frigidaire upright freezer model#
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
8/18/2010 11:08:39 PM • Frigidaire... • Answered on Aug 18, 2010
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
10/13/2009 6:31:28 PM • Frigidaire... • Answered on Oct 13, 2009
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
9/8/2009 5:30:27 AM • Frigidaire... • Answered on Sep 08, 2009
Frigidaire FFU1424DW16 upright freezer. What is the cubic feet of it?
Question edited for clarity and add maker. Question moved to correct category. 16 cubic feet for that series, the '16' in the model number. https://www.google.com/search?q=Frigidaire+FFU1424DW16+freezer+Cubic+feet ..
11/16/2023 3:43:26 AM • Frigidaire... • Answered on Nov 16, 2023
Frigidaire MFC20M4FW3 Freezer. What is the cubic feet of my freezer please?
Question edited for clarity. Question moved from Washing Machines category. It looks to be a standard 20 cubic feet freezer and has '20' in its model number. you can also measure it internally in feet and multiply length x width x depth. https://www.google.com/search?q=frigidaire+mfc20m4fw3+review ..
4/15/2023 6:41:20 PM • Frigidaire... • Answered on Apr 15, 2023
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
2/14/2023 6:48:44 AM • Frigidaire... • Answered on Feb 14, 2023
What is the cubic ft.for a Frigidaire stand up freezer model MFU23BW4
According to the Frigidaire website, the cubic feet for the Frigidaire stand up freezer model MFU23BW4 is 23 cubic feet.
1/6/2023 6:19:01 PM • Frigidaire... • Answered on Jan 06, 2023
2answers
High temp code on my frigidaire upright freezer. What is this and how do I fix it?
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
11/2/2022 6:39:37 PM • Frigidaire... • Answered on Nov 02, 2022
2answers
My frigidaire chest freezer model FFFC07m2kw stopped working and all food thawed inside . we cleaned it out and since when we plug it up it comes on for 5 to 10 seconds and then stops .
if have an amp probe [multi-meter] when turns on check amp draw on motor ----motor failure ---thermostat failure --no freon
8/28/2022 9:00:34 AM • Frigidaire... • Answered on Aug 28, 2022
Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D Logo
20 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
  • Freezers
