20 Most Recent Toshiba Satellite X205 Notebook Questions & Answers
0answers
I need to reset, bypass, or remove the HDD1 PW
Shutdown The System
Press ESC and Power button together
Enter the passwords if prompted
Press F1 to enter the BIOS
Select the password field (it shows Registered)
enter bkspc or space
enter your existing password
press enter
It prompts for New password
Just enter
Repeat for verify
Now password is Unregistered
If you found this post helpful , please rate it!
Regards
1234s282
11/7/2013 2:54:49 AM • Toshiba... • Answered on Nov 07, 2013
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?see method 5 here:http://support.microsoft.com/kb/326253
12/23/2012 1:43:24 AM • Toshiba... • Answered on Dec 23, 2012
Toshiba X205-sli4 lcd flickering
The cause here is a bad backlight, It wouldcost less to just have the whole lcd with backlight replaced. You can pickon up for under $100 bucks, www.ebay.com Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
8/9/2012 3:13:49 AM • Toshiba... • Answered on Aug 09, 2012
How to override user password
You can change or remove a user password provided you can login as an administrator. IF NOT then -
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
6/23/2011 4:44:06 AM • Toshiba... • Answered on Jun 23, 2011
BOot 3 beep then nothing?
Flip the unit on it's back, remove the battery, unscrew the RAM slot cover, remove the ram by pushing the two locking pieces away from the sides of the RAM. remove the RAM then re-seat it back into the slot, replace cover and replace the battery, flip unit back and attempt to boot. If you still get the beeps, note weather they are short or long, short-long-long, or short-short-long etc... it maybe a graphics problem and since most graphics cards on toshiba laptops are built onto the board you will have to replace the system board....is it under warranty? if not you maybe looking at an expensive fix.
11/12/2010 2:42:03 PM • Toshiba... • Answered on Nov 12, 2010
Windows boot manager message on start up
Sincerely, I am really sorry about this but I gotta tell you that your hard disk has crashed.
All you need do is to consult the hardware vendor and see if the data on the hard disk can be recovered and have your system restored to its factory default settings.
Good luck.
2/23/2010 12:25:59 AM • Toshiba... • Answered on Feb 23, 2010
I have a toshiba satellite X205-S9810 and i was
if you mean to replace a screen i advise you have a specialist do it as many things could go wrong and by doing it yourself you have no protection from error, if a techie does it its his A$$ that replaces it if he messes up
1/4/2010 5:09:46 PM • Toshiba... • Answered on Jan 04, 2010
Need help with the area around my keyboard.
I'm sorry but there's really not much you can do to fix this and make it look OK. Your best option is to get a replacement cover from Toshiba.
You could try glue and other home resources but your'e risking permanent damage to the hardware below the cover and a really poor looking laptop.
Best of luck
11/12/2009 5:52:29 AM • Toshiba... • Answered on Nov 12, 2009
Hi i have a toshiba X205-S9800\r\ni want to
If I understood the issue correct you want to upgrade your system. Please start with the following :
1) Add 2 channel RAM or 2x2 gb to improve the memorey capacity.
2) Please add a 500gb hard drive. Beyond this is not comaptible.
3) CPU is the highest you have . Try a new motherboard to allow a CPU of 2.66gigs to be installed.
4) NVidia grpahics card is the best one to be upgraded.
Thanks
10/4/2009 2:03:49 PM • Toshiba... • Answered on Oct 04, 2009
X205-SLi1 Speaker Problem
sounds a lot like you have a speaker that's crying for removal and replacement..you could try to use the volume slider, with the left/right balance, and see if it's generic to the system, or just one particular application. sounds like it's happening all the time your computer is on
4/22/2009 10:18:50 PM • Toshiba... • Answered on Apr 22, 2009
Toshiba laptop Dual display issue
To switch between screens try pressing the FN key and F5. You should not have to restart you computer. As for the TV error "invalad signal" you might have to change the screen resolution on you computer. You might have to try a few different resolution before you find one your tv accepts.
1. Open Display Settings by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
12/22/2008 3:37:26 PM • Toshiba... • Answered on Dec 22, 2008
X205-S7348 HELP
try updating the video card drivers on toshibas website. there are some games that you will not be able to use a high setting on. this system is a good unit but if you wanted better gaming performance would have recommended the x205-sli5 or sli6. the sli systems have two video cards that work together to give you the best possible performance.
11/30/2008 5:54:50 AM • Toshiba... • Answered on Nov 30, 2008
I have had problelms with
Check Power Options in Control Panel if you can turn on the laptop again. or tell me more if laptop is still not on....such as power LED..HDD light..Charge LED...any sound/noisy..?
11/17/2008 5:54:30 AM • Toshiba... • Answered on Nov 17, 2008
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Toshiba Satellite X205 Notebook Logo
22 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
need reset bypass or remove hdd1 pw
  • Computers & Internet
