20 Most Recent Lenovo 3000 Y410 Laptop Questions & Answers
3answers
Media Player cann't read DVD contents & asks for Restart
install the newest vlc player. copy and paste the line below into the url box:
http://www.videolan.org/vlc/download-windows.html
when installing, click on all the file types and install, and it should play the dvd.
i personally would uninstall powerdvd as well, cos vlc plays just about anything i throw at it.
good luck
chris
12/30/2021 3:50:21 AM • Lenovo 3000 Y410... • Answered on Dec 30, 2021
2answers
My laptop is lenovo y
Hi raj,
I see that you are having a Bluetooth issue finding he option sending and receiving Bluetooth transfer options.
On your system whichever windows you may have you can see Bluetooth,
  • Click on Start then click on All Programs, look for accessories
  • Click on accessories it should show you the Bluetooth icon under Accessories if you click on it it will give you the option to send and receive using Bluetooth.
I see that you installed the driver for your Bluetooth to see if it installed properly check device manager, you should see Bluetooth under Network Adapters, if it's not there then the installation was not successful or maybe it just did not install correctly, try reinstalling again.
  • You can also try download an application that can utilize your Bluetooth device for example Blue Soliel that is a good Bluetooth Application that I personally use, you may just need to purchase the program online to be able to use the full functionality of the application.
I hope that his will be helpful regarding your concern, have a nice day.
1/7/2017 5:55:36 AM • Lenovo 3000 Y410... • Answered on Jan 07, 2017
Unlock
Generally, your PC can be unlocked by pressing CTRL+ALT+DELETE and entering your account password.
5/13/2016 12:49:31 AM • Lenovo 3000 Y410... • Answered on May 13, 2016
I dont know to use
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    4/12/2016 6:11:23 PM • Lenovo 3000 Y410... • Answered on Apr 12, 2016
    2answers
    I have recently installed windows
    most likely, the drivers on the CD are not compatible with Win 7. try to download the drivers from the Lenovo support site. look for a compatible Win 7 drivers for your audio controller.
    12/29/2015 11:08:49 PM • Lenovo 3000 Y410... • Answered on Dec 29, 2015
    This is a question and answer session to all
    Good luck with that, windows 7 is better than vista.
    12/28/2015 12:19:58 AM • Lenovo 3000 Y410... • Answered on Dec 28, 2015
    3answers
    I formet my lenovo y410
    Hi
    I think you need to go to the lenovo website to download new drivers for windows 7 hopefully they may some drivers for you
    http://www-307.ibm.com/pc/support/site
    12/20/2015 1:26:12 AM • Lenovo 3000 Y410... • Answered on Dec 20, 2015
    2answers
    From where i can download win8 drivers for lenovo 3000 Y410
    If you have upgraded the Laptop from Windows Vista to Win 8 , Did you do a Hardware compatibility test? You may be in for bit of a mess. Take a look at this: http://howto.cnet.com/8301-11310_39-57390888-285/check-your-hardware-for-windows-8-compatibility/ The driver's are another issue, sometimes you can use Win 7 drivers, change compatibility, and modify the drivers to work with your hardware. I have done it , and it can be quite a pain, and quite frankly not worth it. I would suppest Win 7. When you "jump" two OS's ,Vista to Win 8, it doubles your fun.
    9/17/2015 2:36:21 AM • Lenovo 3000 Y410... • Answered on Sep 17, 2015
    6answers
    Drivers for Lenovo Y410 for Windows 7
    i have install windows7 in my y410 laptop and the sound driver is not working in it.it shows an error massage while i am trying to install the driver.
    9/17/2015 2:35:00 AM • Lenovo 3000 Y410... • Answered on Sep 17, 2015
    42y7470, manual, driver, connection
    hi there wait a moment please
    7/15/2015 1:12:34 PM • Lenovo 3000 Y410... • Answered on Jul 15, 2015
    How do I open my bigpond inbox easily?
    Go to https://messaging.bigpond.com/?cid=Aside-sales-login-module and bookmark it in your browser.
    12/3/2014 6:18:58 AM • Lenovo 3000 Y410... • Answered on Dec 03, 2014
    Mind spark toolbar platform has stopped working
    Reinstall it
    11/7/2014 6:42:17 PM • Lenovo 3000 Y410... • Answered on Nov 07, 2014
    I want lenovo wirless driver for Y410-7757 model for win 7 32 bit.
    From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems. Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer. There is no special Lenovo driver, unless the hardware in your laptop is made by Lenovo. In that case the driver will be on your computer after you installed Windows 7. Perhaps you call something a driver but need something else?
    11/2/2014 4:46:30 PM • Lenovo 3000 Y410... • Answered on Nov 02, 2014
    Google com
    Check to see if you have pressed the Num Lock key. it might be stuck, in whihc case you can try pressing it repeatedly and possibly spraying compressed air and/or electonics cleaner under the keys.
    8/18/2014 5:11:56 AM • Lenovo 3000 Y410... • Answered on Aug 18, 2014
    How to run 3000 y410 laptop in safe mode
    Hit F8 during the boot process to bring up special boot features like Safe Mode. With Windows 8 you can open a search bar and type "Startup". Select Change Advanced Startup Settings". Select Safe Mode. Reboot.
    6/1/2014 4:32:36 PM • Lenovo 3000 Y410... • Answered on Jun 01, 2014
    How to make my Quantary touch pad work and to install if needed
    All touch pads work of the capacitance in your skin. The device requires a driver software to activate it. Open the Wondows Control Panel and look under DEVICE MANAGER before doing anything. Look for a yellow exclamation indicating a hardware error. If one exosts then open it by clicking on it and make sure the driver is installed and is working (which Windows will tell you when you check the driver software itself) and update or replace as necessary. If you can provide the Windows version then I can give you specific keystroke insturctions to do the above if you are not familair with Control Panel
    5/18/2014 3:18:15 PM • Lenovo 3000 Y410... • Answered on May 18, 2014
    Lenovo 3000 Y410 Laptop Logo
    601 questions posted
    Top Lenovo Computers & Internet Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    3000 Lenovo
    • 3000 Lenovo
    Most Popular Question
    unlock keyboard lenovo laptop
    • Computers & Internet
