20 Most Recent
Pioneer VSX-917V-K Receiver Questions & Answers
Repair center
need to replace the power button also check your main board for bad solder bad solder is a little ring around the solder point may also look like it is cracked if so resolder them that might help with your problem k
11/23/2013 10:27:45 PM •
Pioneer...
Answered
on Nov 23, 2013
I am trying to connect
I had basically the same problem with my JVC receiver. It would not work on the DVD HDMI input but worked on the auxiliary HDMI input with my PS3. You might want to try that and see if it works for you.
1/4/2011 8:47:22 PM •
Pioneer...
Answered
on Jan 04, 2011
I have a Pioneer VSX-917V.
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
12/26/2010 8:01:33 PM •
Pioneer...
Answered
on Dec 26, 2010
I used to get OSD
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
1/28/2010 12:48:06 AM •
Pioneer...
Answered
on Jan 28, 2010
While doing A MACC, the receiver will suddlenly
Hello check the Speakers first, Try unplugging all speakers one at a time and turning on the unit, do this until the the overload stops,When and if you solve which one is causing the problem, reconnect the bad speaker by it self to confirm it was the one causing the problem as it will go into overload again. Also make sure no wires are contacting each other at the speaker output terminals. Even one thread of wire touching each other if not using (Banana plugs) could cause the Overload circuit to activate. Also try unplugging all the speakers and turning on the unit to see if it goes into overload. If so then service is needed on the audio amplifier Circuitry.
11/18/2009 9:35:07 PM •
Pioneer...
Answered
on Nov 18, 2009
