20 Most Recent LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Questions & Answers
Disk not recognized with Mac OS X
You need updated drivers to get that working. Get OIbit Drive Booster on the internet at IObit.com
1/2/2019 7:07:14 PM • LaCie Hard Disk... • Answered on Jan 02, 2019
2answers
My Lacie external drive clicks but won't spin up.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
10/28/2018 5:14:04 PM • LaCie Hard Disk... • Answered on Oct 28, 2018
Lacie rikiki 500gb
5/22/2016 11:03:51 PM • LaCie Hard Disk... • Answered on May 22, 2016
How to fix Sara hard disk bad Sector
5/22/2016 9:11:11 PM • LaCie Hard Disk... • Answered on May 22, 2016
2answers
How to recover data from dead sata hard drive
Two things die on most hard drives, The really serious one is that the spindle motor coil opens up and you have a dead motor. But, most of the issues with hard drives ends up being the controller board dying. Look at the model number of your drive and see if you can find a good used one on Ebay that has the exact same model number. They have to match! After getting the same drive usually at a bargain price you then swap the controller boards and they try out your drive. Almost 100% success for me as I have done this many times for friends, family and others who had a drive that died for no reason. Now, if you have dropped your drive then kiss it good bye as the head structure will be totally destroyed! I have taken those apart and removed the platters and put them into a matching drive, this is not for the novice user to do. but its is worth the try if the data is very important. good luck
3/3/2015 5:01:17 AM • LaCie Hard Disk... • Answered on Mar 03, 2015
2answers
Wants me to re-format. how can i keep my documents
download recover my file or ontrack recovery. Recover your files from the hard disk and then format your hard drive if you need crack or serial for the software mail me at [email protected] with the subject recovery crack
12/18/2014 10:57:41 AM • LaCie Hard Disk... • Answered on Dec 18, 2014
2answers
I immediately reformatted my LaCie
Thank you Mr.Tyler & Mr. flamboyant , I can`t doing follow your recomment because don`t automatic driver installation and can`t see in device manager. 28697eb3-0f66-45b4-90a9-bc2db69a6be3.jpg 849cc805-fc90-4c7b-8586-465fd7d402cc.jpg
8/21/2014 12:32:41 AM • LaCie Hard Disk... • Answered on Aug 21, 2014
Bloacked
Try connecting to another pc. Change cables.
6/19/2014 5:37:05 PM • LaCie Hard Disk... • Answered on Jun 19, 2014
2answers
I've using my
If the hard drive(s) have been clicking for a long time, and rebooting randomly for some time, I'm leaning toward the drive(s) being dead. You'll need to do a data recovery on the drive or restore from backup. You should get a new hard drive. Clicking is bad.
4/22/2014 12:43:10 AM • LaCie Hard Disk... • Answered on Apr 22, 2014
Power applications not supported
That means this won't work on a Power PC. Drive should still work.
4/2/2014 12:53:44 AM • LaCie Hard Disk... • Answered on Apr 02, 2014
0answers
All my datas from my imac are now on my LaCie, how do I restore them back to my imac??
The data from LaCie hard drive can be easily restored back on iMac by making use of powerful iMac data recovery tool. Even I had encountered a similar problem and was wondering a way to restore the data on my iMac. Then I got know about this tool which helped me to recover all my data from iMac. Download the software available online and do reply me once you use it.
Best of luck J
Carter
12/29/2012 9:09:00 AM • LaCie Hard Disk... • Answered on Dec 29, 2012
2answers
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
9/19/2012 4:18:10 PM • LaCie Hard Disk... • Answered on Sep 19, 2012
Damaged hard disk
There is no way to retrieve the data, however there are specialty labs out there that can access information in the majority of cases, but be aware that it will be expensive.
9/18/2012 9:28:02 PM • LaCie Hard Disk... • Answered on Sep 18, 2012
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
178 questions posted
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LaCie Computers & Internet
Most Popular Question
power applications not supported
  • Computers & Internet
