20 Most Recent
ATI RADEON HD 2400 PRO Graphic Card Questions & Answers
I want to connect my
HDMI and DVI are both digital signals, therefore if you used DVI - DVI it would be the same as HDMI - HDMI.
If you really want to use HDMI - HDMI you could purchase a DVI - HDMI adaptor for your graphics card. Contact your favorite computer store.
Take care!
damnor01
My Radeon card isn't recognizing the monitor and Catalyst won't read its full resolution (1024 x 768).
Hello there
The HD 2400 is a pretty old card and I doubt it will give brilliant graphics.or will it run DX11
However.
1)Have you disabled the 'on-board' graphics in your BIOS settings ? Your computer will not recognise it if the old on board chip is enabled.
2) Have you tried connecting the 2400 using the 15 pin video connector ?
3) You say it isnt 'recognising' the hd2400 and yet you are saying the monitor is working at 640 !!!! Which is it. Does the monitor work on the old onboard output or the HD2400 ?
4) The version of catalyst depends on your operating system and whether 32 or 64 bit.
Use the right one via here
http://support.amd.com/en-us/download
and uninstall the old one first..
5) If the monitor does not work at all on the HD2400 try the card in a different PCI slot.
6) ALWAYS check after you start the PC that in 'Device Manager' that the display adapter (hd2400) is recognised.
7) run ' DXDIAG ' to see how good the monitor is. (type in dxdiag the start orb search box)
Amd 2400 pro video card, after install and reboot
Please check your motherboard or video cards website to determine if one is compatible with the other. Ensure that the video card is in the proper slot and that it is seated securely. If the video card has a power connector on it you may also need to connect that to your power supply. Of course don't forget the easy to miss things like making sure cables are plugged in, if none of that works the card may be faulty, but if it was purchased recently AMD has an excellent no-questions return policy.
Get "out of range" video display error - screen is
shut the system down and when u hit the power button on the system start tapping the f8 key and select the option safe mode and when in safe mode go ahead and uninstall the driver from add and remove programs in control panel and restart the system and go in to the normal mode and download the latest version and install it
Why is my GPU overheating to 120 c when playing
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Update of ATI Radeon HD 2400 is causing problems -
Click the START MENU, click the CONTROL PANEL. Locate the APPEARANCES AND THEMES link. Click the DISPLAY tab or MONITOR Tab. In this option, a DROP BOX MENU will be available. Click the ATI RADEON HD 2400 PRO device. It may say something similar to MULTIPLE MONITORS. After doing so, you may configure the MONITORS as to giving them a position such as MONITOR #1 AND #2. You may do this by DOUBLE CLICKING the monitor example pictures above the drop box menu to verify which monitor will be your main DISPLAY.
