20 Most Recent
Tomtom One XL GPS Receiver Questions & Answers
No GPS Signal in TomTom One XL all of a sudden
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
How to connect phone bluetooth to tomtom
First enable bluetooth function under the menu options. (if not bluetooth menu button is seen you will need to tap the "show all menu buttons" button in the menu)
once bluetooth is enabled follow the prompts that the One XL gives you to connect device.
Please make sure your device is in discoverable mode (blinking blue and red) during the process.
Map down loads
From what I understand, you have a 30 day guarantee for the latest update map. That 30 day stretch starts from the day of first use (not the time of purchase). It it is not a store demonstration unit then you still have 15 days. It goes without saying that if the licensed map has not updated within the 30 days period, there is nothing to update. You can however still use the Map Share feature to download the minor map corrections.
I suggest you frequently connect your unit to the calculator and the Tomtom Home software will do the automatic updates. If a new map is issued within your 30 period you will get. Even if you missed it you should console yourself in the knowledge that major map update are not that frequent. You can also buy other maps from Tomtom.
Are tomtom updates free?
Not unless it has "free updates for life" but that only lasts until the software is updated normally. You can update the maps but it will cost depending on area.
How do I update my device
Step 1
Connect the TomTom One XL to your PC using the receiver's USB Cable.
Step 2
Launch the TomTom Home software on your PC and log in to your account.
Step 3
Click "Tools" and select "Use Latest Map Guarantee" to begin the update.
How can I switch it
At the base of the device there is a reset button ( a small hole ) You could try to press the button .
the device will reset all its settings back to factory settings.
This way you should be able to go back to the menu and select the language you want again.
