20 Most Recent
Smeg STA4645U 18" Fully Integrated Dishwasher with 5 Wash Cycles, Stainless Steel Racks, 9 Hours Del... Dishwasher Questions & Answers
Smeg integrated dishwasher continually washing -
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Smeg dishwasher displaying Er01 code
This is a possible problem with either the switch that prevents the washer over filling with water during a wash cycle or there is a leak in one of the pipes inside the machine. I would recommend you get an engineeer to look at it as you will need to get inside the machine to repair this.
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible. Refer
this site for 60 inch dishwasher and
this site for 45 inch ones.
