20 Most Recent
Panasonic HDC-SD9 Flash Media Camcorder Questions & Answers
Problems using HD Writer 2.5E with Vista
I spoke to a technician at Panasonic. He said the problem is the 64bit Vista. It may run with the 32bit version, if gives trouble there is a patch update under Global Support/consumerproducts (digital AV window updates) at Panasonic web page. It will work with new Windows 7.
3/15/2011 1:32:31 AM •
Panasonic...
Answered
on Mar 15, 2011
I have a Panasonic HDC-SD9.
http://service.us.panasonic.com/OPERMANPDF/HDCSD9-MUL.PDFTHi sis the manual if you need to study it for anything ..and for the reset I extracted the part that you need to do ...You actually have to press the reset located under the lcd...So flip the lcd..and locate the button and press it using a sharp object or the end of the belt..
Remove the card if it still makes the same ..infact you can remove the card ..than reset ,,and if it makes the same when you insert the card ..format it in the laptop after saving pictures and videos..cause it may have something on it that is incompatible with the camera ..After reinserting it ..format it again in the camera ..
1/21/2011 11:57:55 AM •
Panasonic...
Answered
on Jan 21, 2011
I have suddenly lost all the files held in the
Your camera probably records in a special extension file, that takes your camera's program to work. You can get the program by going to your manufactor's website and download the software.
12/11/2009 10:15:32 PM •
Panasonic...
Answered
on Dec 11, 2009
