20 Most Recent
Frigidaire PLEF398AC Electric Kitchen Range Questions & Answers
My oven is beeping F11. (i unplugged the oven
The
F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven
control board senses a runaway temperature condition in the oven through
the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You
could have a failed oven temperature sensor, a wiring harness failure,
an open thermal switch or a failed electronic oven control board that
would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If
you have a volt/ohm meter, you can shut off the breaker for the range
and remove the screws that mount this sensor to the back wall of the
oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect
the sensor but do not let the wire harness retract back through the
back wall of the oven or it will be hard to reconnect.
Measure the
resistance of the oven temperature sensor with your volt/ohm meter. At
room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If
the resistance is above 2200 ohms at room temperature, then the sensor
probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You
would need to access the electronic oven control board (Timer) in the
console and check the resistance at the sensor circuit connection to the
control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Thanks to blueextc3221 for this solution.
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
[email protected] OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
The front right burner of
PF stands for power failure. That happened when you cut breaker off. Replace switch that controls burner that doesn't work.
Frigidaire Model FEF365BGWE Oven not working, Error F3 on display
I found this:
"F3 - Oven temperature sensor circuit fault
The manufacturer has assigned this error or fault code to indicate that the oven temperature sensor has failed. Test the sensor with an Ohm meter for the proper level of electrical resistance. The sensor is not repairable, if it is defective it will need to be replaced."
If it was me, I'd find the oven temp sensor (long thin metal thing like this:
http://partsdr.com/part/5304497424-oven-sensor-kit/ this may not be the exact replacement part) and examine it. Unplug it and plug it back in. Maybe it's just lost proper contact. If not, don't waste a lot of time one it...just get a new one. They don't cost much.
The front dual burner will not heat.
Then it's just the wire connection at the burners. They're probably burned off and need replaced. I replaced the connectors on my mothers burners and they work fine now.
How to check heating elements in oven
Hello Friend, this is Z. Thank you for your inquiry!
I understand are seeking information on how to check the heating (bake/broil) elements in your Frigidaire oven. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step? Also, may I have your model number please? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side.
My fridgedaire oven will heat up fine on broil but when I put it on bake it only gets to 280 and stops heating
Good Afternoon Friend,
I understand your Frigidaire range, model# PLEF398AC, heats up fine on broil, but only hits about 280 degrees F when put on bake. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and try setting the temperature to 350 degrees on bake. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My frigidaire professional series showing error code F 30 and oven not turning on
Good Morning Friend,
I understand you are receiving an F30 code on your Frigidaire range, model# PLEF398AC, and it will not turn on. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Fes355dsb oven not heating
I understand that the oven is not heating in you Frigidaire range, model# FES355DSB. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and preheat your oven. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best regards-
WP
F10 fault
F1 through F10 fault codes are runaway temperature codes.
If this error code is shown while the oven is in day time mode, the Electronic Oven Control (EOC) would need to be replaced. Otherwise it may be the oven temperature sensor or Resistance Temperature Detector (RTD sensor).
Sounds like you will need to contact an appliance repair technician in your area to test each to isolate the problem.
