20 Most Recent
Canon PowerShot SX100 IS Digital Camera Questions & Answers
FORMATTING
Hvae you tried taking the card out then looking on the camera for any stored images.
A lot of cameras will automatically use the storage card when it is inserted instead of the camera memory.
You maybe out of luck and lost all your pictures.
Using self timer on the
Does the auto exposure go down to 30 secs? If you are getting 30 secs on B mode then the self timer will not work. Set the camera to full auto and then from the menu select self timer, you should have 2 options 2 sec and 10 sec. Then press the shutter
Problem copying videos
Think it is a file issue where the file you have copied to disk is not compatible with what your player can handle. Trick is to convert the file into one that your player can read. Plenty of freeware around for that - just Google it.
Where is the battery compartment for time/date for my Olympus Stylus850 SW ?
If you mean the battery for the time/date in you camera, it does not have a compartment for it, the battery that keeps the time/date is internal. It is usually a button cell like what a watch uses. To replace the memory battery requires to take the front and back panel off your camera, not an easy task. Most of the time it is easy and requires you to remove all the tiny screws around the camera, once you remove all the screws you can pry open both front and rear panels, you do have to hunt for that little button cell battery as every camera has it in a different location?
Blurry picture if zoom is used
Camera shake? When you zoom and make things bigger, you also make movements bigger. So a relatively small movement could manifest as camera shake. Make sure your shutter speed is high enough.
Lens error, restart camera....the lens
hi
if you see lens error on back of lcd and lens barrel is stuck, then your camera would need replacement of zoom control gears or a whole lens unit. Either way your local repair shop would charge you almost same cost depend on time consume. the cost would be around $75 to 135 depend on what they realy want to charge.
Thanks and best regard!
Blurry picture if zoom is used ( no Sharp mage)
I'm out of practice because my camera suddenly stopped working 6 months ago, but I don't recall having a problem with blurry pictures when I used the zoom. Sometimes, it takes a few seconds for a pic to come into clear focus. I think the trick is to just keep working with it.
Canon sx100 display card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
