20 Most Recent
Frigidaire FRS23H5ASB Gallery 22.6 Cubic Side by Side Refrigerator Questions & Answers
Loud noise in freezer. Removed inside panel and ice build up from water line was pushing fan and hitting connector. How do I remove back panel?
You have to find out why the defrost timer did not turn on the mullion strip heaters first. Simply turning the thermostat off for a few hours will melt the ice build up without having to disassemble the refrigerator. Water may leak out on the floor from the ice build up but it will stop soon enough. Back to the defrost timer. It sounds like it is not working or if it is then there are some open heat elements where the ice has built up. The timer is usually located behind the toe grille at the bottom of the frige. Your location may be different, so go online with your model number and look up the exact location.
Compressor wont come on
sounds like it froze up, is the fan in the freezer running? remove everything from the freezer and let it thaw out wait till its warm to the touch, and check the water pan underneath might run over then plug it up again and watch the fan, it must run or it will freeze up again might need oil or just turn it a few times to get it going
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
