20 Most Recent
Canon Pixma MP600 Printer Questions & Answers
My printer will not pring
1. Please check if the ink cartridge is empty or not. If empty or nearly empty, better to change a brand new cartridge as per instructions;
2. Please check if the printer driver installed in the PC is still damaged or not. Suggest to re-install the printer driver once again;
3. Please check if the printer cable (USB/Network cable) is connected firmly from the PC to the printer. If found loosen, please connect it firmly;
4. If you found the printer led light is not turned on even you have plugged the power cable correctly, please change another power cable for testing; or may be the power bar is not working properly;
5. After you tried all these steps and the printer still couldn't work, please disconnect it and send it to the Canon repair center for proper repair and maintenance. Please do not open the chasis of the printer by yourselves.
Display nor readable
Hello, if you need help with your mp600 printer you can download the official service manual from below link:Canon Pixma Mp600 Service manual:
http://goo.gl/1YxeSManual Contains:1. MAINTENANCE 2. LIST OF ERROR DISPLAY / INDICATION 3. REPAIR 4. MACHINE TRANSPORTATION 5. TECHNICAL REFERENCE 6. CLEANING MODE 7. DISASSEMBLY 8. PARTS CATALOG Good Luck
My Canon Pixma MP600 printer has an error coming
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Ink replacement
open the front part of the cabinet and there u get to see the black cartridge gently pull it out and then replace it with new one
We recently got a new Dell I530 desktop computer
Here's a link to the download section at Canon for your MP600. Simply choose your Vista version (most likely 32 bit) and download. it.
Atthe same time you'll notice the operating guides are listed below and you can download them as well.
Good luck
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Pixma 600, yellow won't print
...maybe your yellow nozzle is dirt...full of frozen yellow ink...try to cleaning the nozzles by put a thick paper and run the cleaning program from the printer properties...
Paper is not jammed, however the error screen
try to check inside your printer some small torn papers must have been left inside the mechanism of the printer and that it can detect that is why it keeps prompting a window saying it is jammed.
