20 Most Recent Canon PIXMA MX310 All-In-One Printer Questions & Answers
You need to buy the ink with the new chip installed, or buy a resetter. The only way to print now is with a new cartridge either Canon, or with a new chip.
Canon PIXMA... | Answered 15 hours ago
Hi
You don't need the CD, just go to this site: Driver Update and use their software to update your driver.
Wish you best of luck
Simon
Canon PIXMA... | Answered on Dec 04, 2019
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Go to Start/Control Panel/Printers and faxes. Right click on the Canon icon and click on Offline turn toggle it back to Online. Please rate this answer.
Cheers
Bob
Canon PIXMA... | Answered on Aug 30, 2019
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
Canon PIXMA... | Answered on Aug 19, 2019
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Canon PIXMA... | Answered on Aug 08, 2019
use the PS driver for that
Canon PIXMA... | Answered on Jul 19, 2019
hi..
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board..
thank u
rate me!!
Canon PIXMA... | Answered on Jun 10, 2019
  • Click Start and then click Printers and Faxes to open the Printers folder.
  • If the desired printer icon is missing, please go to Step two.
  • Make sure the desired printer has a check mark next to it which indicates it is set as the default printer.
  • If the desired printer does not have a check mark next to it, right-click the printer icon and then click "Set as Default Printer".
  • Right-click the printer icon, and then click Print Test Page to print a Windows self-test page.
  • If the Windows test page prints successfully, close all windows and try printing from the application you were using before.
  • If the Windows test-page does not print, go to Step two.
  • Step two: Re-install the USB Composite Device from Device Manager
aFor more help visit cbrtechsolutions
Canon PIXMA... | Answered on Jun 04, 2019
Check the print head. Get a cloth and clean out the print head area.
Canon PIXMA... | Answered on Jan 10, 2019
This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Let me know if this works with you
Please rate this solution. Thanks
Canon PIXMA... | Answered on Dec 17, 2018
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Canon PIXMA... | Answered on Dec 11, 2018
Try the below website. It is especially for Canon.
http://www.fixyourownprinter.com/forums/inkjet/42085
Hope this helps and works as it has worked for many others too. I am one of them.
Canon PIXMA... | Answered on Dec 01, 2018
I hope this link helps you to solve your issues http://ugp01.c-ij.com/ij/webmanual/Manual/W/MX450%20series/EN/FAX/FAX_Receiving0920.html
Canon PIXMA... | Answered on Aug 21, 2018
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Canon PIXMA... | Answered on Aug 02, 2018
Hi. That kind of software is almost impossible to get. Search in youtube there are a lot of tutorials about that toic
Canon PIXMA... | Answered on Feb 28, 2018
Hi have you tried to send faxes to another number ?
Canon PIXMA... | Answered on Feb 19, 2018
Canon PIXMA MX310 All-In-One Printer Logo
2,559 questions posted
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon pixma mx330 all in one printer
  • Office Equipment & Supplies
