20 Most Recent
Frigidaire FRS23KF7AB Side by Side Refrigerator Questions & Answers
Waterline on back of refridgerator keeps popping out and leaking
There should be a compression fitting that seals the water tube to the fridge. The fitting looks like a brass or plastic nut that the tubing sticks into. Shut off water supply to the fridge and carefully remove the fitting nut...there should be cone shaped compression ring inside the fitting nut. Slide the nut over the tube, then the compression ring over the tube. If the compression ring is tapered towards one end, then put the narrow end towards the end of the tube. Now stick the tube up to the fitting on the fridge where the nut screws on to the fridge. Hold the tubing firmly against the fitting and slide the compression ring and nut up to the fitting and screw the nut back on (compression ring should be inside the nut). You must hold the tubing firmly against the fitting until you get the nut tightened back down good with a wrench. This should take care of it.
If you find that the tip of your tube end is damaged, then you may have to cut off the tip of the tube to get it to seal and hold. If you find that the compression ring is damaged (won't slide over the tubing) or missing, then you can go to Lowe's or Home Depot and get a new nut and compression ring...they are cheap. You can also get new tubing there if you need it.
My frigidaire side by side freezer freezes up and
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
The temp reads 65f. when I change it to 0-33 it goes back to 65f
Thank you for your post, janet!
I understand that your Frigidaire refrigerator is not displaying the correct temperature. Is it cooling? If it is cooling it could be an issue with your control panel or thermostat not registering the appropriate temperature within your refrigerator. I would suggest performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience a display problem or that refrigerator is not cooling I would recommend reaching out to a professional for proper diagnosis and repair. This will help you to avoid purchasing unnecessary parts. I hope this is helpful. -Matt
Why is refrig so cold its freezing liquids
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS23KF7AB, is so cold that it is freezing liquids inside the refrigerator area. I also see that you have it set on the warmest setting. First, I suggest setting the controls to the factory setting. Secondly, reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, leave the setting on the factory setting, and give your refrigerator 24 hours to stabilize at the factory setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My icemaker is dispensing pink colored cubes.
First of all do not use these pink cubes or drink any water coming from the same source until the cause is nailed down. It could be as simple as making four full bins of ice, discarding each, until the cubes are normal. It could be that your ice maker is fed with a little 1/4 inch plastic line, no longer recommended, which is making the ice pink. [if that is the case change out the plastic with a braided stainless steel line. it will improve the quality of your water now and never ever break on you].
OR it could be a serious problem like water from your toilet tank being drawn back into your fresh water supply. All that being said, begin by not using the cubes and letting the machine produce four bins of ice which u discard. That is the most common fix.
good luck
please rate my anwser as a fixya! thanks
