20 Most Recent
Kodak Easyshare M753 Digital Camera Questions & Answers
Cannot see picture
Hi
This may be the problem with ur CCD .Very rarely optical unit problem. anyhow visit a service centre.
LENSE ERROR 122,1,0,0 problem
Hershey, take a small pair of needle nose pliers and try and wiggle the lens and it should work! I just did it with my daughters camara
(Same camara, same error message) Good luck!!
Lens error, 122,1,0,0
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
How long will the batters last on kodak m753
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given on a battery.)
Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable.
When the light on the charger comes on, you can assume the charger is working.
If you can charge the battery in the camera everything looks the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours.
I have two Kodak Li/ion batteries and after almost 10 years, they are still on good condition. But I also had to trow away lots of other batteries, before they were about one year of age. (I did charge them wrong, with a high current, more then they could handle)
The shutter won't open on my C143 CAMERA what can I do
Try to press the button on top, with the two logos, and make sure you did put the camera in Smart Capture mode. It should work fine then. If it still does not work, contact your dealer, or a certified Kodak service centre.
Kodak easy share C143 the shutter wont open
this is not much to go on. If I would have the camera in my hand, perhaps I should see more. Like if there was a scene on the display, after I switched on the camera.
If everything else looks ok with your camera, pleas look if your camera is still in the Smart Capture mode. Press the button on top of the camera, with the two camera logos on it (still and video camera) en use the arrow up and down keys on the back, to goto the Smart Captuer mode. When there, the camera should work correct. Most of the time, your camera is caught up in a scene mode, like beach scene, and does not have enough light to focus and therefore does not take a picture. It also could be in the video mode, without you knowing.
Success
Lost my cords during a move
753 has a special mini usb cable only from kodak-buy a 20.00 sd memory card reader and use that to download-they work great!
