20 Most Recent
LG 37LC7D 37 in. LCD HDTV Questions & Answers
LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
LG 37LC7D 37 in....
Answered
on Jun 19, 2019
Medion lcd hd 31.5 inch tv won't turn on
I bought one also from ALDI for my son's Xbox 360, it is only 3 weeks in use and I have the same problem. The red led is on, indicating that it is in standby mode and recieving power but I can't turn it on either by pressing the power on button on the TV it's self or the on button on the remote. This started happening a few days ago and it's totally random. I found that if you unplug the TV from the power point or alternatively switch off the power point for a minute, than power it on again it will "WORK AGAIN" for a while. Like I said it is random, eventually it will return to the not being able to be switched on state at which time you will have to repeat the process. So thus, this is not really a solution. I am about to return the TV for a refund, and it's a shame because otherwise it's not too bad. and looks OK too.
LG 37LC7D 37 in....
Answered
on Jul 20, 2018
Audio out of sync with video on LG 37 LCD
Do a factory reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
LG 37LC7D 37 in....
Answered
on Apr 07, 2017
Lg 37lc55-za power problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
LG 37LC7D 37 in....
Answered
on Jun 10, 2016
37 inches lg problem green light on but no picture
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
LG 37LC7D 37 in....
Answered
on Apr 03, 2016
TV won't work after disconnecting toggle from tv
Just try a hard reset to this TV, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
LG 37LC7D 37 in....
Answered
on Oct 26, 2015
