20 Most Recent Vizio VX37L Television Questions & Answers
3answers
How to fix a TV stuck in split screen?
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
8/6/2022 7:06:07 AM • Vizio VX37L... • Answered on Aug 06, 2022
2answers
Hey I'm trying to program my Comcast remote to
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
7/15/2022 7:36:41 AM • Vizio VX37L... • Answered on Jul 15, 2022
2answers
Vizio VX37L HDTV black rectangle in lower right corner
Turn off the Picture in Picture (PIP) option using the remote control. I had this problem and it worked for me!
5/8/2020 1:07:07 PM • Vizio VX37L... • Answered on May 08, 2020
2answers
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input. (option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV. If that doesn't work, try: (option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.Option 2 worked for me!
12/18/2018 2:36:52 PM • Vizio VX37L... • Answered on Dec 18, 2018
0answers
Vizio LCD HDTV Screen is Black No Sound help
Not to be a smart alek but buy a new tv
1/4/2018 5:21:21 AM • Vizio VX37L... • Answered on Jan 04, 2018
0answers
Vizio 37 hdtv problem, blue screen w/ no signal displayed then shuts down in about 20 seconds
The problem is the main digital board. It does not have a reset button.
11/1/2017 6:13:54 PM • Vizio VX37L... • Answered on Nov 01, 2017
No Picture -- just a black screen on my vizio vx37L
Did you hear any pops before the screen went black? You've tried completely discharging it? Disconnect everything off the TV, all cables and power. Press and hold the power button on the TV for at least 20 seconds. Let it sit, and in about an hour, plug just the power in (directly to the wall) and see if it comes on. There should be an indicator light, is it white or orange now? Was it a different color before? Odds are it's a board, be it the main or a video, don't know for sure. If you can take the back of the TV off and see if there are any evident signs of damage, blown or swollen capacitors, burnt traces or resistors/diodes, etc.
10/25/2017 11:47:15 PM • Vizio VX37L... • Answered on Oct 25, 2017
0answers
Sudden no signal on digital channels on a Vizio VX37L
Your cable signals are probably encoded so that you have to use their cable box for reception. Renders your tv tuner useless used for OTA.
8/28/2017 8:57:42 PM • Vizio VX37L... • Answered on Aug 28, 2017
My vizio tv model vw46L gets a gradient black box
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
8/8/2017 11:42:42 AM • Vizio VX37L... • Answered on Aug 08, 2017
8answers
Vizio 37L suddenly stopped getting all digital channels
I had the same problem with my 42" vizio. Was working fine for about a year and a half, then a month after all stations went digital, I couldn't see any digital channels and it wouldn't scan for digital signals
This is a strange go around, but it worked for me. . Tried unplugging, pushing power button for two minutes... did everything the forums suggest, with no resolve. But, here's what DID work for me. Trust me, it sounds strange, but it continues to work (and, yes... it's not a permanent fix... the channels still go out once in a while, but I can always get them back now)
Use your Vizio remote control. Turn your TV on. Press the "input" button until you get to "RGB", which is what you would connect a computer to. Make sure no computer is connected, or it's at least off if it is connected. When you get to RGB, you'll see a message that says "No Signal". After about 5 seconds, the TV will enter a sleep mode and seem as if it has turned off (orange Vizio logo). Once it completes it's little sleep cycle and "clicks" off, wait a few seconds and hit the input button again. It'll go to the next menu item. Keep clicking input until you're back on "TV", and VUALA! The channels are back!
I accidentally figured this out when trying to troubleshoot, but I'm glad I did. Didn't want to dishout $250 to get it fixed. Let us know if it works for you too!
7/26/2016 3:31:06 AM • Vizio VX37L... • Answered on Jul 26, 2016
Vizio vx37l says it has no signal and shuts down before i can change the input
Good common sense idea and I will remember it.
11/30/2015 11:47:25 PM • Vizio VX37L... • Answered on Nov 30, 2015
My Vizio VX37L tv will not turn on. When I plug it in to the wall, the vizio light turns orange but pressing power does not turn the tv on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/6/2015 5:08:37 AM • Vizio VX37L... • Answered on Sep 06, 2015
Won't turn on and either won't turn on orange Vizio light
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/24/2015 5:00:04 PM • Vizio VX37L... • Answered on Aug 24, 2015
3answers
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
2/23/2015 10:14:24 AM • Vizio VX37L... • Answered on Feb 23, 2015
Why do i get a blue screen when turning on cant change channels
Sounds like tuner fault. Contact any service technician. Electro help
12/22/2014 4:12:44 PM • Vizio VX37L... • Answered on Dec 22, 2014
Vizio VX37L Television Logo
228 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
hey trying program comcast remote
  • Televison & Video
