20 Most Recent Sony KDL-32M3000 32 in. LCD Television Questions & Answers
My Sony Bravia is stuck on channel 2 and won't
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
9/12/2021 10:46:33 PM • Sony KDL-32M3000... • Answered on Sep 12, 2021
My Sony KDL-32M3000 has dark
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
4/4/2019 7:23:51 AM • Sony KDL-32M3000... • Answered on Apr 04, 2019
Mr. bkphillip635, awhile ago you posted a question about your Sony KDL-32M3000, and according to fixya your question was answered. You and a bunch of people looked at the answer. Now, I have the exact
Recommend contacting your nearest authorized service center directly or online here: Most of the time however, it is simply cheaper and easier to replace the television. At today's price point, they are practically disposable. Contact Sony Support helpful-hhkqfx2w2zkuwwpsab3b1hzw-3-0_22.png
2/7/2018 5:34:34 AM • Sony KDL-32M3000... • Answered on Feb 07, 2018
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
12/10/2017 10:43:03 PM • Sony KDL-32M3000... • Answered on Dec 10, 2017
Can't remove the subtitles from my sony bravia tv
Hello !
I would you to try this open the back disconnect the power cable to the video card  of the set  then put it back  then on it .
Remember when doing this make sure there's no power coming in from the wall socket  otherwise u will be short circuited
good luck
7/30/2016 9:03:27 AM • Sony KDL-32M3000... • Answered on Jul 30, 2016
I have a Sony Bravia Model No. KDL 32M3000. There is no sound. Is there a fuse or something that needs replacing? All wired are attached.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2/11/2015 1:17:27 PM • Sony KDL-32M3000... • Answered on Feb 11, 2015
Why would the volume stop working on my TV?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
2/11/2015 1:16:24 PM • Sony KDL-32M3000... • Answered on Feb 11, 2015
Slow moving dark picture, low color resolution
You probably have a bad main digital video board. I would not suggest a person with prior electronics experience to perform this repair as the set holds extremely high voltages for hours after being turned off.
If you want to try it yourself, you can get the replacement part here
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1016710-SONY&Click=17845
A service manual would come in handy when you are working on something like this. You may want to try searching for one before starting this repair. If you cant find it then let me know and I will guide you with the repair.
8/7/2014 7:54:00 PM • Sony KDL-32M3000... • Answered on Aug 07, 2014
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
3/23/2014 7:22:10 PM • Sony KDL-32M3000... • Answered on Mar 23, 2014
My Sony KDL-32M3000 flashes on and off for Maybe 1 second each time and the entire screen will occasionally flash to multiple color snow. Can this worth repairing?
The cost of the repair would be quite close to a purchase of a new same size TV. It is safe to use unless you start to hear crackling noises which indicates short circuitingGood Luck Ed Pinero
2/7/2013 5:19:55 AM • Sony KDL-32M3000... • Answered on Feb 07, 2013
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
1/1/2013 6:53:37 PM • Sony KDL-32M3000... • Answered on Jan 01, 2013
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
12/16/2012 4:07:29 AM • Sony KDL-32M3000... • Answered on Dec 16, 2012
How many omi do you need for tv repair
Question does not make sense, are you able to provide more information?
11/7/2012 1:58:02 PM • Sony KDL-32M3000... • Answered on Nov 07, 2012
Unable to change picture aspect
If remote has the aspect button it will do this depending on signals--some boxes preset the aspect for the signal they are outing to your TV---4x3 for example may not be able to be switched to full or 16x9.
11/6/2012 1:40:36 AM • Sony KDL-32M3000... • Answered on Nov 06, 2012
My tv has very slow picture developing and some discoloration
Sounds like a bad LCD panel tab. Sony and Samsungs are notorious for that. Just search Youtube for "bad LCD tabs", and you will see videos of the actual problem and symptoms.
10/19/2012 6:14:52 AM • Sony KDL-32M3000... • Answered on Oct 19, 2012
Sony KDL-32M3000 32 in. LCD Television Logo
69 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
sony bravia
  • Televison & Video
