20 Most Recent
Samsung LNT5265F 52 in. LCD HDTV Questions & Answers
On my sumsung lnt5265f 52 in hdtv lcd tv the power
The issue has been resolved. I removed the back of the TV (pretty easy
actually) by laying a blanket over the kitchen table and placing the TV
face down. I started with the power supply as an obvious beginning.
Both fuses on the board tested fine. And touched up every solder joint
with a hot soldering iron in case the problem was a cold solder joint.
After this painstaking venture, I performed another visual inspection
and noticed a capacitor that had a thin black X on the top of the can.
This is a common sign the capacitor has over heated. I located a
replacement for $1.20, installed, and successfully powered up the TV. I
have had no problems since.
Oh, yeah, I also paid $120 for a BN44-00150A replacement power supply,
plus overnight shipping. It actually arrived three weeks later. That
was two weeks and six days after I fixed the power supply myself.
[email protected]
This TV constantly shuts itself off.
Tv clicks with no picture
This is a common problem with all Samsung flat panels. The problem is caused by faulty capacitors on the Power board. It is an easy fix if you have basic soldering skills. You can also call Samsung and see if your tv is covered under the class action and they will send a tech out to replace the board.
No audio
Either gonna be an issue with your speakers or more likely it will be that you need to replace the main pcb. What is the model and version # for your tv?
Vertical lines
Most likely the lines are coming from a failing LCD panel tab connection. The capacitor problem and LCD tab problem are the most common problem for older Samsung LCD's
Samsung 52 inch LNT5265F has
This sounds similar to a known problem with bad capacitors in some Samsung TVs. Even though the TV is out of warranty, Samsung extend the repair period for affected TVs. Get your TV model and serial number off the back and then call Samsung at: 1-800-Samsung (1-800-726-7864). Explain the problem and let them know that you have heard about similar problems and heard they were being repaired out of warranty. In my case, they sent a tech out and did the repair for free. If for some reason they will not do it, the repair is quite simple for someone who can solder and you can find details here: http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
Tv turns on for a
Most likely your backlight inverter is defective. On a set this big, the inverters should be seperate boards. It could also be leaky caps in the power supply, or a defective mainboard that isn't holding the "BL ON" signal. The tv is repairable but most repair shops will want to gouge you on price.
When turning on TV Samsung 52 , 3 years old it
This is common problems for LCD tv,most likely because bad components parts call capacitors on the tv power supply board.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or roll of desoldering braid also can do basic soldering and understanding basic electronic?Take the tv aparts.Yes,check all over the power supply board for capacitors parts are bulging up or puffing up.By replacing all these dying capacitors components parts,will help ur tv LED power light stop blinking and the tv will work right away.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
