20 Most Recent Sony STR-DG510 Receiver Questions & Answers
Code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
7/3/2018 8:00:25 AM • Sony STR-DG510... • Answered on Jul 03, 2018
0answers
0answers
0answers
No audio
Be the first to answer 3/1/2014 10:12:09 PM • Sony STR-DG510... • Posted on Mar 01, 2014Be the first to answer
No phono input
You will need a pre-amp with a RIAA curve. This is vital as the output from a vinyl disc is nothing remotely like flat. It is also at a very low level and will need to be boosted to go into your receiver. RIAA pre-amps are widely available and you get what you pay for. Once you have bought one you should be able to plug its output into the aux on your receiver.
2/18/2014 11:41:33 AM • Sony STR-DG510... • Answered on Feb 18, 2014
No sound from the speakers
check your connections if they are good another problem I could see possibly happening was if the wires for the speakers were plugged into the amp while it was turned on the wires may have touched together and blew the side out of your amplifier.
12/23/2013 4:22:42 AM • Sony STR-DG510... • Answered on Dec 23, 2013
Connecting sonly bravia tv to old sony receiver
Does the tv have an optical output jack? If so, that is probably the easiest way.
12/19/2013 4:22:32 PM • Sony STR-DG510... • Answered on Dec 19, 2013
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
12/17/2013 5:07:35 AM • Sony STR-DG510... • Answered on Dec 17, 2013
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
7/7/2013 6:52:04 AM • Sony STR-DG510... • Answered on Jul 07, 2013
How do I switch from coax to hdmi on my Sony receiver?
on the sony site it says the hdmi into the reciever is for the video, relayed by another hdmi to the tv, the audio will still be the coax I personally would use the hdmi from dvd directly to the tv, and the coax from dvd directly to the reciever and call it a day
3/8/2013 3:43:11 AM • Sony STR-DG510... • Answered on Mar 08, 2013
It goes into protect mode then shuts off. its not the fuse and i have unpluged all speakers and it still goes to protect mode then shuts off.
I had the same issue - I found that there is a square chip, about an inch and a half from the amplifier chips and heat sink, which got so hot (i could not even touch it), it was seperating one of its pins from the circuit board (due to a hairline crack on the pin itself. When it got that hot, ther metal pin seperated at the crack which made this chip short out, creating the "protect" to happen. I resoldered the solder joints on the circuit board where the pins of this chip connected and fixed the cracked pin with a jumper strand of wire, then made an aluminum heat sink and connected it directly to the chip -no more issues!
9/2/2012 4:38:46 AM • Sony STR-DG510... • Answered on Sep 02, 2012
How do you connect the denon 4308 to your home network?
You need to change the internet settings in the user menu tor the new setup.
7/12/2012 6:51:14 PM • Sony STR-DG510... • Answered on Jul 12, 2012
Sony STR-DG510 Receiver Logo
110 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
opened amplifer top
  • Audio Players & Recorders
