20 Most Recent
Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Questions & Answers
I have a 27" Frigidaire
If the elements are good and you have checked the obvious connects etc. then it would seem to be the control circuit.
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to
assist you. Typically, error code F4 indicates a lockout error. Try resetting
the unit by unplugging it or flipping the household circuit breaker off. This
usually clears most false error codes. Wait approximately ten minutes and if
the error code does not clear, I would recommend contacting a professional to
proceed further. Most likely the EOC (electronic oven control) or the Lockout Control
Board on the appliance will need replacing.
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally,
qualified technicians often perform complicated part replacement such as this,
however this may or may not be specifically for your model. Below are generic instructions
that I found on how to take your oven door apart to remove any stains that may
be caught down in the door vents.
Tools
needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly
off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining
assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing
up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost
clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the
wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned
without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Oven door display comes on
Hello mapatt - Are you able to open or latch the door? Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. This will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs. The unit could possibly be experiencing a wiring failure, faulty light switch, door latch or EOC.
Replace light bulb
Hello tony sunlitis - I understand that you would like to know how to replace the light bulbs in your unit. So I can assist you better in pinpointing you the information, may you please provide me the model number.
My oven door is locked.
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The
only button on your stove that should make the door lock would be the
clean button (self clean model) if that is pressed simply hit the
clear/off or cancel key and wait for the door to unlock. IF the self
clean option ran for an hour or so, you will have to wait for the oven
to cool down before the lock can unlock (safety feature).hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
Remove oven racks and soak them in soapy water.
Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
Let the oven do its work;it will heat for several hours, charring off baked-on foods.
Fast Cleaning
Remove oven racks and place them in soapy water to soak.
Preheat oven to 200 degrees.
Turn the oven off and spray the inside with oven cleaner.
Allow to sit for 10 minutes.
5
Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
6
Dry with a soft cloth.
thank you.
Upper oven onlyworks on broil. When I turn the
could be a bad element or a wire burned out,going to the element in the back of the oven. you will have to pull out the unit to check the wire. turn off the power to the oven before you start. element can be checked from the inside.
