20 Most Recent Jenn-Air JFC2070KRS Bottom Freezer French Door Refrigerator Questions & Answers
Compressor is humming and not cooling
Replace the start relay on the compressor. Here is the part you need.
10/28/2012 8:54:31 PM • Jenn-Air... • Answered on Oct 28, 2012
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.5_20_2012_4_36_48_pm.jpgI will be here should you have more questions, Thanks Sea Breeze
5/20/2012 4:40:16 PM • Jenn-Air... • Answered on May 20, 2012
Jenn-Air JFC2070KRS leaks from bottom....why
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
8/31/2011 1:02:46 AM • Jenn-Air... • Answered on Aug 31, 2011
My Refrigerator isn't working properly.
I don't think that you should do this one . the problem mey be several . 1 may be the evap has iced over and this is a defrost problem . the other is a control problem which would cause the ice problem and no defrost / my guess is it's a control failure a nd will require a replace or it . this is called in the service ( the jazz board ) .. the board is not cheap and if you buy it and install it ( its yours ) .. .. hope this helps mm feed back pls ..
3/6/2011 8:14:09 AM • Jenn-Air... • Answered on Mar 06, 2011
The refrigerator is not cooling
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
2/24/2011 7:27:58 PM • Jenn-Air... • Answered on Feb 24, 2011
Freezer works fine, top not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
11/25/2010 9:35:19 PM • Jenn-Air... • Answered on Nov 25, 2010
I'm a tech working on this Jenn-Air fridge...evap
an evaporator coil freeze up is usually caused by low freon
10/28/2010 1:13:03 AM • Jenn-Air... • Answered on Oct 28, 2010
Original cost of my fridge from 1999
2389 model Jeff of Clayton, CA Original review: June 2, 2006 We purchased a Jenn-Air JCD2389GES side by side four years ago. We thought we were buying a quality refrigerator, with a name brand that was respectable and with the idea that you get what you pay for. We went ahead and spent $2200 on purchasing this and within a year noticed that it made noises, the refrigerator side didn't stay cold and the freezer side froze food that developed freezer burn with in a week. Just this past week the refrigerator was on the coldest setting and the food was slightly above room temperature. A hundred dollars of food had to be thrown away. ---------------------------------------------------------------- The best way to find old prices is to find reviews. The best ones are on websites that do reviews themselves as they always list the price. https://www.google.com/search?q=jenn-air+jcd2289atb+review ..
5/30/2022 4:00:51 PM • Jenn-Air... • Answered on May 30, 2022
Can't adjust trisensor climate control. Stuck at 0 and 38 and is freezing things in fridge compartment.
It's a Jenn-Air, you will need a service call. They are totally electronic and very complex. Look in the manual first as there may be a child lock function on the controls. It sounds like a thermister has failed though which is a temperature control device. It shouldn't freeze at 38'F, 6' above freezing.
10/19/2021 4:43:59 PM • Jenn-Air... • Answered on Oct 19, 2021
Jenn-Air Fridge Leaking from Bottom AFTER drain tube is clear
then look under it and find out many things we can not do for people
8/28/2021 9:50:51 AM • Jenn-Air... • Answered on Aug 28, 2021
Jennair refrigerator demo mode
Press lock and light for 3 seconds
8/20/2021 5:34:00 PM • Jenn-Air... • Answered on Aug 20, 2021
JennAir refrig/freezer model: JFC2089HTB2. Both are heating well above temperature.
Hi! Please check the troubleshooting part of the manual to a similar JENN-AIR fridge https://manualsbrain.com/en/manuals/947419/?page=15
2/28/2019 9:51:17 PM • Jenn-Air... • Answered on Feb 28, 2019
Jenn-air side by side refrigerator the ice maker works but the water dispensor doesn't. You can hear a hum in the door when the lever is pressed.
Possible faulty water solenoid valve may be the problem not letting water through.
11/5/2018 2:06:23 PM • Jenn-Air... • Answered on Nov 05, 2018
Jenn-Air JFC2070KRS Bottom Freezer French Door Refrigerator Logo
18 questions posted
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Refrigerators
Most Popular Question
refrigerator not cooling
  • Refrigerators
