20 Most Recent Nikon N2020 35mm SLR Camera Questions & Answers
Pull the leader over to the orange mark, then close the back.
Nikon N2020 35mm... | Answered on Nov 19, 2017
is the battery for the meter good ?
Nikon N2020 35mm... | Answered on Feb 13, 2015
needs repairing at a qualified shop
on the bottom,
Nikon N2020 35mm... | Answered on Jan 16, 2015
On the bottom, Remove Silver screw,
Battery holder is under bottom cover. Remover large silver screw. Clean battery holder in case of leakage
Nikon N2020 35mm... | Answered on Oct 14, 2014
Open the Menu. Go to the "Setup Menu" (wrench symbol). Scroll to "Image Comment". Use the "Image Comment" or "Attach Comment" choices to change the Metadata information (up to 36 characters).
Nikon N2020 35mm... | Answered on Sep 24, 2014
There is no power button. Simply press the shutter release button halfway to turn the camera on. The camera will shut off after a few seconds of inactivity.
Nikon N2020 35mm... | Answered on May 10, 2014
Bottom of the camera, just behind the lens mount.
Press the shutter button half-way. The camera will shut off after a few seconds of inactivity.
Nikon N2020 35mm... | Answered on May 08, 2014
did you clean all contacts? never use anything sharp in or closet to a camera. To clean contacts in a camera and on the batteries, just use a dry cloth and a cotton swab. My 20 year old camera's (same brand and a canon) still work as the first day I used them. they are always stored dry and without a battery, when I don't use the for a longer period.
Recheck the manual (yes most manuals from Nikon are still online) if you did setup the camera correct.
Nikon N2020 35mm... | Answered on Apr 25, 2014
Put a drop of isopropyl alcohol on a Q-tip and rub them.
Make sure Asa dial is set to auto and not set on a fixed asa setting
Nikon N2020 35mm... | Answered on Jan 21, 2014
If you think the contacts are dirty or oxidised, you could try to clean them with a cotton swap and a prop of contact oil. But be sure you can remove all the oil you apply.
Be aware to move the contacts as little as possible. You are allowed to pus them in, but move them sideways can cause them to lose the correct position or worse they can be broken.
It is great to see, Nikon USA, still has lots of manuals of the elder SLR camera's
Nikon N2020 35mm... | Answered on Jan 15, 2014
Nikon N2020 35mm SLR Camera Logo
43 questions posted
Top Nikon Photography Experts
Ric Donato
Jeff
Jeff
Richard C Cohen
Richard C Cohen
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
am novice photographer nikon 2020 af
  • Photography
