20 Most Recent Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Questions & Answers
unplug for couple of minutes for thermostat to reset then plug it back
Whynter FX-6SW... | Answered on Dec 06, 2016
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
Whynter FX-6SW... | Answered on Mar 05, 2012
why are the car looking at me?
Whynter FX-6SW... | Answered on Jan 16, 2011
call primo water corp. for parts!
866-429-7566
Whynter FX-6SW... | Answered on Nov 26, 2010
I need to do the same thing. Please let me know if you were able to get this done. It would help me out alot. Thanks you.
Whynter FX-6SW... | Answered on Nov 18, 2010
i think it may be two option either your heater thermostate switch ,heater timer aren't working or it has a problem of the water. check the tds of the water.or you should check the heater capicity as well as set the water heating temp.
Whynter FX-6SW... | Answered on Feb 25, 2010
see if the compressor is working or move the thermostat to a highter level
Whynter FX-6SW... | Answered on Nov 12, 2008
you have to open it up and look where the water is dripping from. it could be from the rubber hoses that connects the tank to the faucets.
if it's on the hoses, that would be easy to replace, but sometimes the leak would come from the stainless tank whiich would be very hard to replace.
tnx 4 using fixya,
drcool
Whynter FX-6SW... | Answered on Oct 14, 2008
Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
25 questions posted
Top Whynter Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Whynter Water Filters & Coolers
Most Popular Question
black decker water dispenser
  • Water Filters & Coolers
