20 Most Recent
Fuji FinePix S700 Digital Camera Questions & Answers
Can't move photos from internal memory to memory card
Yes, it can be done. Here are the steps to copy them over:
1. Turn on your camera
2. Press the button to view the pictures you have taken (the button that has the green sideways triangle with the green square around it).
3.Press the Menu/Ok button
4. Arrow down to "Copy"
5. Press the Menu/Ok button
6. To copy the photos from the internal memory to an SD card simply hit Menu/ok button again.
7. Arrow down to "All Frames" and then press Menu/Ok
8 It now asks you to confirm. To continue copying the pictures over, press Menu/Ok again.
9. It will now begin copying your pictures over.
There you go. Hope this helps!
How do I change the AVI file extension on video
Dear Deemax1,
There are hundreds of software available on internet to convert avi to wmv or to any other file format. I searched Google with "avi to wmv converter" and I received about 5,250,000 results. Please download any free software and that should do the trick.
Hope that helps. Please let me know in case any further assistance is required.
Regards,
Srinivas.
CAMERA GOT WET WHEN BTL OF WINE BROKE IN SAME BAG.
I am afraid that there is only a small percentage of luck that your camera isn't destroyed. If it was in the bag with the wine for a long time then the wine certainly went into the camera circuits.
What you can do is take it to an electronics service shop and ask them if they could open it, remove the components and clean them with special solutions to remove the sticky wine.
Hope it works.
Lenses
No. The S700's lens does not come off. You can add some accessory lenses to the front, but it's not the same thing as swapping one lens for another.
Flash won't pop up
I have a couple of Fuji S700 cameras and one of them recently came down with the same issue. The flash would partly open but not pop up all the way. I decided to open the camera up and find out what was really wrong. It had been sticking before and the above suggestion about blowing it out helps, but this issue is where it unlatches, pops up part way but doesn't go all the way up and if it doesn't go all the way up the flash doesn't work.
The problem is there is a spring insite the flash hinge that pops the flash up once the electronic latch is opened by the auto exposure circuitry. One end of the spring goes into a hole on the part of the flash that pops up and this plastic part is simply too thin for the force on it and it breaks over time. Bad design.
I should say I first thought about a couple of workarounds. One was real easy if you are not too handy. Take a small rubber band and run it from around the eyepiece to around the "lobe" under the flash. When you weant to use the flash, depress the shutter half way to unlatch it, then move the elastic from the lobe to under the raised flash and it will hold it up. You can leave it up all the time if that works for you. It didn't fit my case with the flash up all the time so I decided to forge ahead... Buying a new case might have been a wiser choice :-)
By the way, its not easy to get into the flash area. I pretty much had to completely disassemble the camera, and I got in a fight with a very high voltage capacitor for the flash that holds its charge for a VERY long time after the batteries are out AND it holds enough charge to get you a few times so use a resistor to discharge it when you get into that are or else... be afraid, very afraid. Seriously. Before you disassemble read on...
If you had a very tiny right angle philips screwdriver you could probably do this repair without taking things apart. The key is there are two screws that hold the top cover of the flash area on. This is the area you need to get at to fix this spring. These screws that are only accessible when the flash is popped up and even then you can't see them as they are recessed. If you can get those screws out somehow then you can do this without a nightmare. If you take the whole thing apart then welcome to hell. I am just on my way back from hell. Hope mine works when I get it back together.
I chose to epoxy a small bent pin in to replace the broken plastic part. I used a long square wire wrap pin, bent it to the right shape and cut it to the right dimensions then glued it in place using epoxy. There is a fair amount of room for glue in there, but be careful not to get it into the area where the lower shaft has to slide back and forth as the flash pops up and down. I used 5 minute epoxy and first just used a tiny dab to hold it in place and I positioned it carefully and let that set. Then I did another glue job to add some strength. Position, then reinforce.
I will try to post some pictures in a followup.
Once a frame is erased is it gone forever even though there is a frame #?
That depends on where it was. If it was on a memory card instead of the camera's internal memory and if you haven't done anything else to the card since erasing the frame, you MIGHT be able to recover it. It's just like any other erased file on any other hard drive.
Do a Google search for "data recovery software" and select a program for your computer and operating system. Take the memory card out of the camera and put it into a card reader attached to your computer. Cross your fingers and run the program.
