20 Most Recent
HP Deskjet F335 All-In-One InkJet Printer Questions & Answers
I checked everything, the printer is connected,
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Ink smears ,
You need to clean the print head until the smears clear up
Hp f335 just refilled ink carts. Now i keep
Unfortunately there is no way to reset the electronics on this type of cartridge so your printer will always think they are empty. If the light flashes and you can still print, then just ignore the flashing. If your printer won't allow you to print, then the cartridge electronics must be bad. If the electronics are bad, there is nothing you can do to rescue the cartridge and you need to get a new one. I would return the cartridge to where you purchased it from and instead see if you have a Cartridge World store in your area. These stores would not sell you a refilled cartridge with bad electronics.
I have an E in my display
HiCheck for paper jam on your printer.Look through the paper paths and remove any obstructions.Try turning the printer off and on.Disconnect it from power and then re-connect after a while.
Error-offline , ran out of paper
Open the printer with the four corner screws. reviews the large gear on the left, must be fixed to the shaft, or gear swept the break with use. Any of these 2 solutions can help you, are most common. another may also be that the rubber is worn separation, this is a line of orange or green you can see from the back when you remove the paper guide, if the rubber has a wear mark, ideally change or lowering the mark with friction. Good luck.Note: for better review of mechanisms, it should remove the rail which moves the carriage. are 5 screws. easy
