20 Most Recent
LG V181 DVD Player/VCR Questions & Answers
What kind of DivX files
PLAYABLE CODEC FORMAT
files DIVX3xx - DIVX4xx - DIVX5xx - XVID - MP43 - 31VX
PLAYABLE DivX file -.avi,.mpg,.mpeg
I can't play all regions DVD movies. Can you send
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Will a VHS from America
Hi
All American VHS recordings will be in NTSC system. If your player is compactable with NTSC system, you can play the VHS in your system. If it has no NTSC syste, the tape will play, but colour problems and vertical rolling will occur. OK.
HI
My LG V181 DVD Player
Divx compatibility with this player is limited as follows; available resolution size of Divx is under
720x576 pixel - file name Divx subtitle is avail by 56 characters - if number of the screen is over 30/sec the unit may not operate norm - playable Divx file avi,mpg. .mpeg - playable codec format
DIVX3.xx - DIVX4.xx - DIVX5xx -XDIV - MP43 - 31VX - if the video and audio structure of recorded
file is not interleaved, either video or audio is outputted.- if the fie is rec GMC the unit supports only
1 point of the record level - may be helpful!
How to unlock LG dvd/vcr model no/ v782w
try that:
- Power on (with no disc inserted)
- Press PAUSE
- Press 3, 1, 4, 1, 5, 9
- Enter the desired RC
- Press PAUSE
- Turn the player off and wait a few seconds
- VCD playback
- Press PAUSE, 1, 4, 7, 2
- Press UP 6 times, '07 00' should appear on the display
- Press Program 6, Program 5 ('07 FE' should be displayed)
- Press ENTER
- Press RETURN
- Power off and on again
My portable dvd showa ero when playing
I had a problem like that before .I thought it was the dvd disc, but it was the laser head. I changed the laser head and all is good now.But it is not portable.
