20 Most Recent
LG RC797T Questions & Answers
I have Dish Network and I can't find a Code for my
I'm assuming you are referring to using the dish network remote to control your DVD/VCR unit. Use the instructions in your Dish Network manual, mine is on page 61, "Setting up using device code tables". Refer to the table of device codes in the back of the dish manual, pg 119, to look up your manufacturer. I used the DVD codes for LG as LG wasn't listed on DVD/VCR combo codes. Try each one until one works. I have the LG RC797T and the third code worked 824. Good luck!
4/7/2015 9:05:19 PM •
LG RC797T
Answered
on Apr 07, 2015
Lg dvd combo won't power up
Some one needs to at least if no power light open the unit and look for a fuse--if power light is there and will not function at all it may or may not be economical to repair this unit.
5/6/2012 2:36:57 PM •
LG RC797T
Answered
on May 06, 2012
Lg dvd player tray not opening and cd remains
possible cause is the lens of the dvd player is already been damage, try to use CD cleaner first if the problem still exist just sent it to a tech person to assist your problem on actual. Thanks
9/15/2011 7:56:18 AM •
LG RC797T
Answered
on Sep 15, 2011
Will not play most dvds
- Hi, I can help.
- Sounds like the lens is just really dirty. Go buy a leans cleaner disk and run it through the DVD player two or three times to get the lens good and clean. Repeat about once a month to keep the lens clean and running properly.
- These disks I speak of have little bristles on it that "sweep" the lens clean. I use them on all my disk players and they work real well.
- If you have any comments please feel free to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
8/26/2011 8:24:59 AM •
LG RC797T
Answered
on Aug 26, 2011
When utilizing the DVD player
The new recorder comes with security systems in it - when it encounters programs that have a "Do not Copy" signal on them it will refuse to work. This is how it's designed to work, there's nothing you can do to change that. BTW , even if you could do that it would have been illegal - recording a copy-protected program is considered by the lawyers of the channel in question as piracy .
The older one didn't do that because it didn't had the security system.
3/13/2011 8:02:50 AM •
LG RC797T
Answered
on Mar 13, 2011
Power is intermittent. The unit will turn off by
I'm having the same problem with the power being on one minute and then there's just nothing there the next, can be out for hours and then just all of a sudden comes back on, have tried different power points etc, anyone got any ideas? bad wiring?
Ally
2/17/2011 11:53:07 PM •
LG RC797T
Answered
on Feb 17, 2011
I have an LG RC797T.
Yes, you can connect another VCR to the LG's video & audio input jacks and record from the external VCR. You may have to select the line input from the menu to activate these inputs.
10/29/2010 4:00:33 PM •
LG RC797T
Answered
on Oct 29, 2010
Need manual for LG RC797T
You can download the instruction manual in PDF format by clicking this
link.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using
FixYa.
6/25/2010 12:34:38 PM •
LG RC797T
Answered
on Jun 25, 2010
