20 Most Recent HP DeskJet F380 All-In-One Printer Questions & Answers
You can call hp tech support toll free number - 1-866-987-2474 and they will give you all information regarding to your printer. for more information you can visit HP Customer service.
Hope this will help you better.
HP DeskJet F380... | Answered on Feb 13, 2020
Hello there Andoni,
What particular model of the HP F4100 series is your printer? For the F4100 series, you can choose among the installation driver here:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=ca&h_query=HP+Deskjet+F4100+All-in-One+series
Hope this helps.
HP DeskJet F380... | Answered on Dec 04, 2019
You can call hp tech support toll free number - 1-800-585-2494 and they will give you all information regarding to your printer. for more information you can visit: HP Customer service .
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
HP DeskJet F380... | Answered on Nov 06, 2019
download driver for your particular operating system
https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-1000-printer-series-j110/4066042/model/4066376
HP DeskJet F380... | Answered on Sep 24, 2019
instal my printer without the cd installer HP Deskjet 1051
HP DeskJet F380... | Answered on Aug 24, 2019
i was in HP tech support supporting AIO printer models, Just click on the link u will get a popup window to download the Driver for ur Printer.
http://snipurl.com/f380_driver_xp
HP DeskJet F380... | Answered on Jun 20, 2019
Hp deskjet f2280 pinter don't install in windows 7. now what can i do ?
HP DeskJet F380... | Answered on May 29, 2019
To get the drivers select the link below
http://www.siliconguide.com/drivers/device/617/
when you get to this website select right download for your operating system, save file and install, that easy
cheers
Brett.
HP DeskJet F380... | Answered on May 21, 2019
Go to hp.com, product support, download driver, type in your model number and go.
HP DeskJet F380... | Answered on May 07, 2019
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
HP DeskJet F380... | Answered on Sep 12, 2018
Next page gives support for HP F380, Windows 7 32-bit:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4062&lc=en&dlc=en&cc=us&product=1128296&lang=en
For other Operating Systems for the F380, go to next link and select the required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
HP DeskJet F380... | Answered on Feb 16, 2018
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
HP DeskJet F380... | Answered on Feb 15, 2018
I lost the CD installer of my HP Deskjet F380, how I can install it?
Is it a legit HP ink cartridge? I have had a few knockoffs fail to be recognized in my printer. Seems like the printer companies are getting wise to the knock off brands
HP DeskJet F380... | Answered on Feb 12, 2018
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
HP DeskJet F380... | Answered on Feb 01, 2018
Might be scanner drivers corrupted, Reinstall the Scanner drivers again. Most probably this will work greatly You can try this no (877-690-9305) for the solution. Support For Hp Printer
HP DeskJet F380... | Answered on Jan 30, 2018
Recognition of cartridges depends on several issues. Check and clean the metal contact points on the printer cartridge slot. Use rubbing alcohol on a q-tip and pat dry. Do the same on the ink cart. Any oil/film on the contacts can interfere with the communication network of the printer. Sometimes, printers just reject cartridges, mainly if you use off brand products. Naturally HP wants you to use their cartridges! Other than that, you must use HP Software updates for the computer and also, update each HP Printers FIRMWARE. Lots of folks forget that!
HP DeskJet F380... | Answered on Jan 12, 2018
HP DeskJet F380 All-In-One Printer Logo
2,556 questions posted
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
lost installation cd need install
  • Office Equipment & Supplies
