20 Most Recent
Kyocera FS-2000D Laser Printer Questions & Answers
Kyocera FS2000-D error message 7410:0017578
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
How can i see the serial number or how do i reach it cause i cant
press manu button then go to service then press right errow key goto status page press double enter it will print around 5 or 6 page in second page in down you can find the serial number or else see the back side of the printer it should stikared.............
Call Service F000 error
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Any clue what error code 6030 is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Call service 7000:0165540 FS 2000D
Are you using manufactures toner, my guess are it is after market toner or not seated correctly, or the toner cartridge has a busted gear, either way.. try a different toner cartridge. 7000 error indicates the toner motor cant turn. the 0165540 is the page counter;
Toner motor lock error
A motor over-current signal is detected
continuously for 5 seconds since the
toner motor is activated
;) hope this helps
cheers
Kyocera FS-2000D shows call service 7410:0130324
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Web password
You probably have a network card called a IB-30 installed. You will need to reset this card by changing the jumper from is original position to the next one. This will restore the original factory settings, there are only one jumper on the card. If you still have the CD your IB-30 came with it will explain to you under troubleshooting how to restore the factory defaults.
"add paper cassette"
Turn the printer off. Pull the paper cassette out and push down the green tab down to see if there is any paper jam inside. put the cassette back in and turn the printer on. Worked on my kyocera FS - 1370 DN.
