20 Most Recent
RIM BlackBerry 8700c Cellular Phone Questions & Answers
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Lost my BlackBerry
if you call your provider, they can check to see if any activity has been on it.
Iwant a copy of blackberry 8700c manual to read
http://na.blackberry.com/eng/deliverables/2590/index.jsp?name=BlackBerry+8700+Smartphone+-+User+Guide87004.5&language=English&userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+8700+Series
The Touch screeen on my z10 BB does not work. it was not dropped - just stopped working
2 things come to mind:
The cable that connects the touch part of the screen is loose or has disconnected somehow. You will need to open the phone to make sure.
Your screen may have died. It happens.
I recommend you bring it to a local repair shop to make sure, if it's just a loose cable it's best to let them do it for cheap, as you may break small chips while opening the phone.
I hope this helped.
Unlock Blackberry unlock code
HI if you are in need to unlock your Blackberry 8700c mobile from network lock .Then visit
Simpleunlocking.com here they ask you the country name from where you bought your mobile ,network name to which your mobile is locked and the IMEI number of your mobile .Then they deliver you code to unlock your mobile.
How to unclock a blackberry curve 9300 that has a personal password
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter
any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Blackberry
Curve 8310 mobile phone, your phone may get hard locked and sometimes
become unusable.1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
