20 Most Recent
Kyocera SoHo KX1 Cellular Phone Questions & Answers
Reset phone.
go to a computer engineer for him to reformat ur phone for u but before u do that try and transfer ur dicument into ur system so that u don't loose them wen reformating the phone
Am having kyocera kh520, when i insert the usb the
Hi, Some phones requires you to install the usb driver first before you can use the usb with the phone.
Also You can use other usb cables to test if the usb is working properly.
I think that will do.
Take care.
I'm not recieving any text messages through my
check with your provider to make sure that it is enabled on your service plan. Here we have to pay to receive txt msgs and you have the option to turn them off to prevent spam and unwanted txt msgs being sent to your phone.
Won't begin to charge up
I talked to a rep for cricket that deals with Kyocera and he says its fried, and you cant even get the software, no less want to get it to fix it. I will never get a kyocera again as my cell provider nor kyocera gave me a reply to the issue! Anyone with a cricket, get a verizon and have it flashed over, i did that and loving it, everything worked.
Stop Spamming.
Sahaja Yoga is not a SPAM. This is operational amongst about 140 Countries and is must to save this world now. This is Free of Charge and IN NO WAY IT CAN BE TAKEN AS A SPAM.
How to bypass a pin code on lock screen on a Kyocera phone
All I can suggest for this is to take it to mobile phone specialist. They will have the tools to help. There is a possibility they will have to do a 'Hard' reset which often mean resetting to phone to factory settings. This means you risk losing your personal information like phone numbers, Photos and stuff you've saved on the phone. Pin codes are a security feature so naturally are hard to bypass.
Kyocera e4810 with which carriers
The Kyocera E4810 is also known as the Kyocera DuraForce Pro 2 and it is compatible with a variety of carriers in the United States, including:
- Verizon
- AT&T
- T-Mobile
- Sprint
- U.S. Cellular
However, it's important to note that some carrier-specific features may not work if you're using the phone with a carrier it was not originally designed for.
Regarding the issues you're experiencing with Tracfone, it's possible that the phone may not be compatible with their network or there may be a configuration issue. You may want to contact Tracfone customer support or visit a Tracfone retail store to see if they can assist you with getting the phone to work on their network
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
- From any Home screen, tap Apps.
- Tap Settings > More > Cellular networks.
- Tap Access Point Names.
- If available, tap the T-Mobile US APN.
- If not available, tap the New APN icon.
- To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
- Verify and update the following settings for the Data APN:
- Name: T-Mobile US
- APN: fast.t-mobile.com
- Proxy: <Not set>
- Port: <Not set>
- Username: <Not set>
- Password: <Not set>
- Server: <Not set>
- MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
- MMS proxy: <Not set>
- MMS port: <Not set>
- MMS protocol: WAP 2.0
- MCC: 310
- MNC: 260
- Authentication type: <Not set>
- APN type: default,supl,mms
- APN protocol: IPv6
- APN roaming protocol: IPv4
- Enable/disable APN: <greyed out unless there are multiple APN's>
- Bearer: Unspecified
- MVNO type: None
- MVNO value: <Not set>
- Tap the Menu icon with three dots, then tap Save.
- Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
- Tap Network operators.
- Wait while the device populates a list of available networks.
- Tap the desired network you wish to register on.
Switch 2G / 4G
- Tap Preferred network types.
- Choose from the following options:
- LTE/WCDMA/GSM (Auto mode)
- WCDMA/GSM
- GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
- From any screen, swipe down from the top of the screen.
- Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
- Tap to turn Data Roaming on or off.
Turn on / off mobile data
- From any Home screen, tap Apps > Settings > Data usage.
- Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547 If you need further help, I’m available over the phone at
https://www.6ya.com/expert/daniel_a4640839dbb7ec58
My instagram not working on my android
This happened with facebook on my android. First try resetting your phone (turn completely off then back on). If that does not work go to settings and completely uninstall Instagram. Go to play center and re download it.
