20 Most Recent
Sony Ericsson W700i Cellular Phone Questions & Answers
Video recording
Hi
open the camera shutter select the video recording >click on settings > click on shoot mode > select High Quality Video nad now you can shoot unlimited video
Hw to play avi files
Unfortunately your phone can't play .avi files. The only video formats it supports are .mp4 and .3gp. You will need to convert your .avi file to one of the two file formats I mentioned in order to watch the video on your phone. Good luck!
Actually my mobile battery is draining very fast
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Low sound when battery is low
This is the usual problem.
Even me, I am encountering the same problem with my Nokia Handset.
You don't need to worry man, just Chill!
please rate if satisfied by my answer.
How to lock my phone
By default, your phone lock code is 0000 but you can change this to any 4 to 8 digit code you want. To edit your phone lock code, go to:
Settings >> General tab >> Locks >> Phone Lock >> Change Code.
Now, to set the phone lock,
Go to Settings > the General tab > Locks > Phone Lock > Protection and select an alternative.
It is important that you remember your new code because you have to take the phone to your sony ericson retailer to unlock it.
Hope this helps...Good luck!
Why did it become very hot when battery was inserted?
I would try another battery. If it still happens the trouble is your phone. If it doesn't the trouble was the battery. That's your next step.
Ask a new question stating that a new battery did not solve the problem if the issue persists with a new battery.
If this is the battery you're looking for, then try this link to buy another battery.
http://www.newegg.com/Product/Product.aspx?Item=9SIA3H731N9895 It is a very reputable site. If you want one cheaper, I have also included a choice from Amazon. The phone is lists is supposed to have the same battery as your phone.
Want to flash my phone
if you wont a factory reset this is it :
1. shutdown the phone
2. hold volume up button and press the power button
3. when manufacturer logo come realise the power button but keep hloding the volume button to get into recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind the all data in the phone will be erased (apps & games)
ALL DONE!!!!
