20 Most Recent Frigidaire FRS6R5EMB Side by Side Refrigerator Questions & Answers
Ice maker connection keeps cracking and flooding my house
sometimes ice makers get iced up inside the fill mechanism and causes this to happen. Have you tried defrosting the freezer? This may take care of your problem.
3/13/2017 11:15:09 PM • Frigidaire... • Answered on Mar 13, 2017
We just experienced a power outage and now the
try unplugging it for five minutes an then plug it back in the default settings should appear
6/29/2015 9:49:26 PM • Frigidaire... • Answered on Jun 29, 2015
Freezer and refrigerator are too warm
Good Morning Friend, I understand that your Frigidaire refrigerator, model#FRS6R5EMB, is not cooling well. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/30/2014 2:09:06 PM • Frigidaire... • Answered on Jun 30, 2014
How do I turn off ice maker
Good Afternoon Rsimmon5, I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off. To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position. If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps. -Best Regards- WP
4/8/2014 8:29:49 PM • Frigidaire... • Answered on Apr 08, 2014
2answers
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
10/29/2013 9:57:25 PM • Frigidaire... • Answered on Oct 29, 2013
Power supply
Good Morning Jim, thank you for your post! I am happy to assist you, however what exactly is your concern or the issue your appliance is experiencing? May I please have the model number? You can typically locate the serial tag inside the cabinet, on the left side wall. With this information I can better address the issue. Thank you and I look forward to your response.
9/18/2013 10:21:36 AM • Frigidaire... • Answered on Sep 18, 2013
0answers
Amanda side by side wont dump ice. What can I do to fix. Have no money
Hello zinnas - If your refrigerator has completely stop making ice, try checking the following:
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
If any of these suggestions prove to be infective, connect with a professional to accurately pinpoint any potentially more serious issues.
2/5/2013 4:08:27 PM • Frigidaire... • Answered on Feb 05, 2013
Freezer not freezing food
Hi webdeb1228 - Hello - Sounds like the unit could possibly have a floating restriction in the lines or something more complicated like an issue with the sealed system that only a professional can help with. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. I suggest cleaning the unit out including the coils you can reach, and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
1/15/2013 6:29:06 PM • Frigidaire... • Answered on Jan 15, 2013
Where is the drain hose for a frigidaire model frs23lh5ds9
Hello mcdh109 - Generally speaking, side by side refrigerators have a drain pan located on the right hand bottom side that in some models it is not removable. The unit does not actually have a drain hose.
12/19/2012 7:30:51 PM • Frigidaire... • Answered on Dec 19, 2012
How long should the water filter last
Hi dduke3406120 - Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency to ensure the highest possible water quality.
11/16/2012 9:03:41 PM • Frigidaire... • Answered on Nov 16, 2012
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
124 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
freezer not freezing food
  • Refrigerators
