20 Most Recent
Frigidaire FRS26H5AS Side by Side Refrigerator Questions & Answers
Very little water pressure & no water to ice maker
The solenoid valves, located in the lower back of the refrigerator, where the water line enter the unit has a filter mesh at the inlet. Mineral formation or debris from the tube lines block the water pass and present the symptoms you describe. Also, when units do not have this filter mesh, the mineral deposit and debris obstruct the water valve mechanism and the water flow. If you have good pressure at the valve entrance, but not at the output, replace the solenoid valves.
I have a model FRS6LF7FM8
You need to evacuate the refrigerant urgent to get the moisture out of your system.When you insert refrigerant ,"let it pass through a drier before it get into your system refrigerator.Only then you have a moisture free refrigerator.Many refrigerant comes with moisture these days but no technicians use a drier to prevent the moisture to fill into the system.They love to see you come back so they can charge you money again.
Oil leaking out from under freezer side.
That oil is probably compressor oil. If the compressor leaks, you need a new fridge. Sometimes they only leak when they're charged up. That would explain the other symptoms.
Frigidaire side by side making a vibrating/humming sort of sound
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Plrs267za
What is it doing, or not doing? Any alpha-numeric error codes or flashing lights?
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
The digital read out shows 56 will not reset will not despense water or ice
Good Afternoon Friend,
I understand that you are receiving a 56 code on the display of your Frigidaire refrigerator, model# FRS26H5AS. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 is actually SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Refrigerator is freezing food
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Ice crusher stuck on crush
your ice solenoid is frozen. It is located behind the ice bucket next to the auger motor. It will need to be removed, unfrozen, and squirt a little wd40 to prevent it from happening again
