20 Most Recent Electrolux EDW5505ESS Built-in Dishwasher Questions & Answers
I start the dishwasher...it works fine, but for
Don't know the brand, but always check the website and select the service tab. Youtube may also have a fix for this. If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
3/3/2018 4:53:38 PM • Electrolux... • Answered on Mar 03, 2018
My electrolux dishwasher will not start. lights on the panel are on but will not start
What to Do When the Dishwasher Won't Start - YouTube
? 5:43 https://www.youtube.com/watch?v=L-bMqVb9kX0 Aug 15, 2013 - Uploaded by doityourselfstan I was stressing out because we could not afford a newdishwasher .... The power come on and the unit fills with water, but then does nothing.
Electrolux® Dishwashers - ElectroluxAppliances.com‎
Adwww.electroluxappliances.com/‎rating for electroluxappliances.com Luxurious by Design, and Featuring the 30 minute Fast-Wash Cycle!
11/20/2015 12:01:27 AM • Electrolux... • Answered on Nov 20, 2015
My electrolux dishwasher will not start and no lights on panel
Good Morning Friend, I understand that your Electrolux dishwasher, model# EDW5505ESS, will not start and the control panel seems to be dead. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. Once power is restored, if the panel is still not lighting up, I suggest contacting your local authorized technician. I do not suggest trying to repair it yourself. There could be something other than the panel, which is causing the dishwasher to seem dead. The technicians will be able to diagnose your appliance and determine what is causing the panel to not light up. Hope this is helpful. -Best Regards- WP
5/21/2014 12:56:23 PM • Electrolux... • Answered on May 21, 2014
Dishwasher door drops suddenly on opening
Most likely one side or the other has a bolt or fastener that gave away. You will have to take the door off to see what is going on in there by the hinge point.
1/11/2014 10:00:06 PM • Electrolux... • Answered on Jan 11, 2014
I have an Electrolux EDW5505ESS dishwasher. The
Hello James, thank you for your question! Since you have already tried resetting the dishwasher and based on the symptoms you are describing, the dishwasher could possibly be experiencing one or two things: a potential wiring failure, or a communication error with the control board. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
9/16/2013 5:44:17 PM • Electrolux... • Answered on Sep 16, 2013
0answers
My dishwasher electrolux esl6115 is leaking from
My dishwasher electrolux built in unit was leaking, turned out to be the plastic nut inside on right hand side where water feeds the top rotar was loose. I actually took side off and found it running down inside and flooding out the feet and sides. Solution in my case was to wrap PTFE around the threaded section and rescrew nuton tightly..Problem solved. Simples.
3/7/2011 4:46:02 AM • Electrolux... • Answered on Mar 07, 2011
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
8/31/2009 1:54:17 AM • Electrolux... • Answered on Aug 31, 2009
Anti flood reset on a Electrolux washing machine
See page 28 Solution to Common Problems in user manual for help User manual Electrolux ELFW4222AW (English - 32 pages)
1/20/2024 1:26:42 PM • Electrolux... • Answered on Jan 20, 2024
2answers
Electrolux dishwasher wont stop draining
Hi I think I’ve got the same problem that the overflow plastic tray didn’t move down due to dirt. See pic. Anybody an idea how to open/ remove and clean this tray on Electrolux dishwasher?
11/12/2023 8:46:46 AM • Electrolux... • Answered on Nov 12, 2023
Parts of electrolux esl6201lo dishwasher presure switch
The pressure switch in a dishwasher, like the Electrolux ESL6201LO, is a component that helps regulate water levels and prevent overfilling. It's an important part of the dishwasher's water management system. However, I must clarify that specific part numbers, designs, and configurations can vary by model and production date. If you're looking for parts or information about the pressure switch for your dishwasher, I recommend the following steps: 1. **Consult the User Manual:** Check the user manual or documentation that came with your Electrolux dishwasher. The manual might provide information about parts, part numbers, and troubleshooting for your specific model. 2. **Electrolux Customer Support:** Reach out to Electrolux's customer support or service center. They can provide you with accurate information about the pressure switch and help you find the correct replacement part if needed. 3. **Online Appliance Parts Retailers:** Websites that specialize in appliance parts, such as RepairClinic, AppliancePartsPros, and eReplacementParts, often provide diagrams, parts lists, and compatible replacement parts for various appliances, including dishwashers. Search using your model number to find the pressure switch or related parts. 4. **Local Appliance Repair Shops:** Local appliance repair shops often have access to a variety of appliance parts, including pressure switches. They might also be able to assist you in identifying the correct part. 5. **Electrolux Authorized Service Centers:** Contact authorized service centers for Electrolux appliances. They should have access to genuine replacement parts and can provide professional assistance. When searching for parts, always make sure you have the correct model number and, if possible, the part number of the specific component you need. This information will help ensure that you get the right part for your dishwasher model.
8/20/2023 2:29:00 PM • Electrolux... • Answered on Aug 20, 2023
Electrolux ESL5201LO dishwasher beeping fault -
8/15/2023 10:05:41 AM • Electrolux... • Answered on Aug 15, 2023
Electrolux dishwasher erorr c4
buy the manual or get it fixed? moved you out of cars
2/14/2023 1:13:49 PM • Electrolux... • Answered on Feb 14, 2023
What is error code c13 - Electrolux Dishwashers EHT8ILG8 MODEL
Error code C13 on an Electrolux dishwasher model EHT8ILG8 indicates a problem with the water supply to the dishwasher. The code specifically refers to a problem with the water pressure, which could be caused by a clogged water inlet filter, a malfunctioning water inlet valve, or a problem with the water supply hose. To troubleshoot this issue, first check the water supply hose to ensure that it is not kinked or clogged. Then, clean the water inlet filter and make sure that the water supply to the dishwasher is not restricted in any way. If the problem persists, it may be necessary to call a professional technician to diagnose and repair the dishwasher. Please keep in mind that this is based on general information, the error code meaning may vary depending on the model and brand. It's recommended to check the dishwasher manual or contact the manufacturer's customer service for more specific information.
1/30/2023 12:32:10 AM • Electrolux... • Answered on Jan 30, 2023
Hi, my Electrolux diswasher ESF 45030 is stuck on draining mode
i think that is engaged via a _(i can't think of the word.. it's a points set that works off an electro-magnet) if that got stuck then it will keep the pump engaged in the drain mode.. otherwise it's an issue with the settings.
12/13/2022 4:18:59 PM • Electrolux... • Answered on Dec 13, 2022
Electrolux WT55 Commercial Dishwasher. Hello, after replacing the cycling pump at WT55, dishwasher stops after 30 seconds at both programs.
Question edited for clarity and full 'make model (what it is)'. Question moved from Cars and Trucks category. It is a commercial unit and should be repaired professionally. Help in the link https://www.google.com/search?q=electrolux+wt55+overheating+solution ..
12/6/2022 10:53:02 PM • Electrolux... • Answered on Dec 06, 2022
I have a 7 year old top of the line Electrolux dishwasher and during the wash cycle it stops and beeps (120 time) . Does anyone know if this is a control panel issue?
It could be anything. They have a diagnostic brain that creates beeps or codes, but never hear of one that beeps 120 times. You can try power cycling it. Remove mains power for 2 minutes and try again. If that doesn't fix it you will need a service call. If it is the control board, you may consider a new machine is a better option.
12/2/2022 3:57:09 AM • Electrolux... • Answered on Dec 02, 2022
2answers
Electrolux dishwasher over flows
Hi, Please pour soap and/or toothpaste at the bottom of the washer. This should unclog any drains that the dishwasher uses. And you can also remove any debris present at the bottom of the dishwasher as well. Otherwise, you need to schedule a home depot repair appointment please. Thank you.
11/10/2022 6:37:44 PM • Electrolux... • Answered on Nov 10, 2022
Electrolux EDW5505ESS Built-in Dishwasher Logo
16 questions posted
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
electrolux dishwasher will not start no
  • Dishwashers
