20 Most Recent Carrier Beverage Air® WTR72A Questions & Answers
Supra 744 bad fuse code ?
Check wiring
7/9/2021 9:16:18 PM • Carrier... • Answered on Jul 09, 2021
Carrier error code EF
All the Carrier codes are here by model number
Fault Codes ' Carrier Air Conditioner
www.carrierair.com.au > installer-and-technical-support
Links to all of the fault codes of Carrier air conditioning system. Please visit this page. ..
1/27/2021 10:02:10 PM • Carrier... • Answered on Jan 27, 2021
Carrier XQB153D makes a loud buzz when trying to start compressor (heating or cooling). This is repeated at intervals. Sometimes compressor starts - and it runs normally for that cycle. What is wrong?
does your a/c have an alarm for short cycle? if the compressor is noisy you should read the run capacitor with a tester equipped with that function, and make sure that it has the correct voltage applied.
1/22/2021 10:15:56 PM • Carrier... • Answered on Jan 22, 2021
The water filter cartridge is lodge in the carrier in our side by side refrigerator? How do we get it out?
You failed to stipulate the make and model of refrigerator. Usually the information on how to remove a stuck filter is located in the owner's manual.
Here's a link from the Whirlpool website on how to remove various filters when they get stuck.
https://producthelp.whirlpool.com/Refrigeration/Full-Size_Refrigerators/Product_Info/Tips_and_Tricks/Removing_a_Stuck_Water_Filter
4/22/2020 9:26:47 PM • Carrier... • Answered on Apr 22, 2020
Carrier unit pro earth ultra
clean your condenser with air pressure to blow out the condenser or use spray bottle to wash down the condenser and fan blade wipe down and make sure all lint is removed from air flow passages!
1/16/2018 1:51:16 PM • Carrier... • Answered on Jan 16, 2018
30GXmanual chiller
replace the oil pressure transducer with a new one!
1/16/2018 1:40:37 PM • Carrier... • Answered on Jan 16, 2018
Our -12F design freezer was
you have another leak it has to be found by an experienced person, usr nitrogen to pressurize the system to over 200 pounds pressure then check again, use squirt bottle with soapy water to find leak, if no leak to be found then the leak is where u are putting your service gauge manifold set on, the shreader vales are not setting!
1/16/2018 1:37:01 PM • Carrier... • Answered on Jan 16, 2018
I have a very old
Hello, Paulfreling - I did not find a link to the manual for your Beverage-Air unit on the company web site: https://beverage-air.com/parts-service/ (Parts & Service page, with links to manuals and videos at the bottom of the page) I suggest you call Customer Service at Beverage-Air and talk with someone there who may be able to direct you or provide you with the right manual. See the Technical Services Department phone number at the bottom of this page: https://beverage-air.com/customer-support/
1/14/2018 5:41:33 PM • Carrier... • Answered on Jan 14, 2018
My Carrier 58STA quit. I killed the power and then started it after a minute or so. It started working fine after that. It worked fine for another 2 1/2 days and then it repeated the process.
this sounds to be a tricky kinda sensor fault , that's shutting it off , this is why it restarts when pwr is reset (resets safety shutdown) also this model is known to have control board faults due to control board being mounted right on blower housing (vibration) id have a tech ck it out they should be able to see if its a flame sense sensor or contrl board error
12/21/2016 2:21:54 AM • Carrier... • Answered on Dec 21, 2016
Why does my Carrier 4 ton condenser compressor turn on and off ever 4 minutes?
have a ac specialist check the charge pressure in the system I suspect that the refrigerant gas amount is not correct and the problem is that the pressures sensors are causing it to cycle according to the fluctating pressures
4/27/2015 1:34:41 AM • Carrier... • Answered on Apr 27, 2015
ALARM AL-15 ON CARRIER REEFER
hola qtal como estas, tengo un problema con un reffer de carrier modelo thinline con motor resiprocante que me da alarma al 15 y para el equipo no baja ninguna llave solo protege
3/19/2015 12:59:19 PM • Carrier... • Answered on Mar 19, 2015
0answers
0answers
0answers
0answers
Carrier Beverage Air® WTR72A Logo
0 questions posted
Top Carrier Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Refrigerators
Most Popular Question
write green advert about use cloth bag
  • Refrigerators
