20 Most Recent
Conair Deluxe Rechargeable Beard & Mustache Trimmer Questions & Answers
Changing trimmer heads on Conair Beard Trimmer - Model GMT188
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
My age is 22.
its a heridetary problem in most cases. there is a simple solution from which most people have been benifited. take a ginger and just chip the upper portion by blade . rub twice daily and you will get the result in 3 months time.
Conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
How do you use a
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
