20 Most Recent
Delfield Undercounter Freezer - 407 Questions & Answers
We have a Delfield 407 freezer that will freeze
You will need to replace the temperature assembly on the unit. If you can post the model number, I will be able to direct you to the parts you need. The model number will be something like "18648-BUC".Regards,Richard
12/3/2011 2:13:14 PM •
Delfield...
Answered
on Dec 03, 2011
Need to repair a pluged cappilary tube
Your best bet is to order an OEM capillary tube and replace it. Of course this requires recovering the refrigerant. The likelihood of unplugging one is very very slim unless it is a very large bore tube.
11/21/2019 9:22:22 PM •
Delfield...
Answered
on Nov 21, 2019
Superheat subcooling
the model says that this is a cooler/freezer combination unit. super heat has to be measured on each section separately. As a general rule: Freezers run around 6-8 degrees and coolers are 8-10. I have seen freezers go as low as 4 degrees right before they hit set point temp and shut off.
6/29/2017 2:16:26 AM •
Delfield...
Answered
on Jun 29, 2017
