20 Most Recent
Delfield 032-6151XLSH Half Height Solid Door Reach in Freezer 51 Questions & Answers
Delfield refrigerator not cooling
Have you fully vacuumed the unit before recharging it? If not most probably the humidity left in there has condensed and it has partially blocked the circuit. Add to that the fact that because of this extra air you have loaded less than what you should of coolant - R22.
7/17/2010 10:26:19 AM •
Delfield...
Answered
on Jul 17, 2010
Need to repair a pluged cappilary tube
Your best bet is to order an OEM capillary tube and replace it. Of course this requires recovering the refrigerant. The likelihood of unplugging one is very very slim unless it is a very large bore tube.
11/21/2019 9:22:22 PM •
Delfield...
Answered
on Nov 21, 2019
Superheat subcooling
the model says that this is a cooler/freezer combination unit. super heat has to be measured on each section separately. As a general rule: Freezers run around 6-8 degrees and coolers are 8-10. I have seen freezers go as low as 4 degrees right before they hit set point temp and shut off.
6/29/2017 2:16:26 AM •
Delfield...
Answered
on Jun 29, 2017
