20 Most Recent Altec Lansing Stereo Headset with Microphone Headset Questions & Answers
0answers
My altec stereo headset(backbeat) headphones
When this happens with these units, unfortunately it means that the Bluetooth electronics, in particular the receiver has failed. In reality there is NO repairing these as one simply cannot get parts. The ONLY option you have is to return it to the manufacturer, and i think you need an RMA number, You need to contact them and inquire as to the procedure for repair.
Costing usually are fairly minimal,as they are mindful of the costs involved.
Either that or toss it out and obtain a new unit.?
8/15/2010 3:28:00 AM • Altec Lansing... • Answered on Aug 15, 2010
Query regarding mic support in Windows Vista
Yes you do indeed need to have Vista Drivers, That said sometimes the XP drivers MAY work if they and the software are installed in XP Compatibility Mode. Vista has been a nightmare for us in the Computer repair industry... one can only hope that all driver issues are addressed in any service packs to come? I doubt it tho...It seems a case of out with the old and in with the new...wheather ya like it or not.
3/28/2009 5:08:39 PM • Altec Lansing... • Answered on Mar 28, 2009
2answers
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
1/15/2009 6:57:33 PM • Altec Lansing... • Answered on Jan 15, 2009
3answers
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
11/1/2008 4:37:26 AM • Altec Lansing... • Answered on Nov 01, 2008
EX-02s mic not working
I have giotech ex-02s and when I hook it up to my ps3 it won't charge how do I fix this?
6/21/2013 10:01:31 PM • Altec Lansing... • Answered on Jun 21, 2013
Having trouble getting sound into
This link below, provided by Skype, has pictures to walk you through the procedure of configuration for the Windows and Skype portion of the configuration .
http://www.skype.com/help/guides/soundsetup_xp.html
Here is the link to the Windows Vista instructions:
http://www.skype.com/help/guides/soundsetup_vista.html
2/22/2010 7:13:48 PM • Altec Lansing... • Answered on Feb 22, 2010
Is there something special I need to do to get the
Shouldn't need drivers for this. Open System Preferences, which can be found in the Utilities folder, if it is not already on your Dock. It looks like a light switch with an apple logo on it. From there select Sound, under the hardware section. Click output, select the headphones, select Click input, again select the headphone/mic set. If it is not on the list, then so sorry, i was wrong, you need drivers, which you should be able to get from the altec lansing site.
If this is set and you still cant here, please let me know what system he is using. Is it the in game one from WoW? Ventrilo? If vent he will need the server data etc. from his guild or friend he is trying to speak with. If it is the in game one, just tell him to follow the in game instructions, they are fairly straight forward.
9/6/2009 12:44:25 AM • Altec Lansing... • Answered on Sep 06, 2009
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM • Radio... • Answered on Apr 19, 2024
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
The LED light display is not working on the face of detachable headset is there some button i can press to enable Firetail FT-8238D
I have the same problem. When o remove the interface the led is not flashing as per the instruction manual
3/27/2024 5:24:11 AM • Radio... • Answered on Mar 27, 2024
I need a manual for a TRONIC PLL 2023 radio. Can you help? Ray
http://www.manuals.group/results.php?search=TRONIC%20PLL%202023%20KURZ
3/26/2024 7:06:10 AM • Radio... • Answered on Mar 26, 2024
I have a Sonoff switch device which worked fine until I changed Broadband. Now the eWeLink cannot pair to the device??
Home - SONOFF OfficialSONOFF Official https://sonoff.tech Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!‎SONOFF Products · ‎Basicr2 · ‎ZigBee Bridge · ‎Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official https://sonoff.tech > product-review > tutorial > how-to-p... How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
3/24/2024 6:49:12 PM • Radio... • Answered on Mar 24, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please. Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity. https://www.google.com/search?q=KPG-790 ..
2/15/2024 3:06:45 AM • Radio... • Answered on Feb 15, 2024
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero. https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive https://www.google.com/search?q=KEM+P29923 ..
2/9/2024 1:12:05 AM • Radio... • Answered on Feb 09, 2024
New Motorola Mag One radio fully charged will transmit but will not receive. why?
This question edited for clarity. Contents of correction Question added here and Deleted. Did you read the Manual? It looks like it has Volume Buttons on the side and may be set to Zero volume? https://www.motorolasolutions.com/en_us/support.html https://www.motorolasolutions.com/en_us/products/two-way-radios/analog-business-radios/portable-radios/bpr40.html#tabproductinfo ..
1/18/2024 7:03:58 PM • Radio... • Answered on Jan 18, 2024
Altec Lansing Stereo Headset with Microphone Headset Logo
Popular Tags
11 questions posted
Top Altec Lansing Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Radio Communications
Most Popular Question
skype not working
  • Radio Communications
