20 Most Recent Jenn-Air JED8430 Electric Cooktop Questions & Answers
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Jenn-Air JED8430... | Answered on Jun 29, 2019
In case anyone else encounters this problem here's what
worked for me. I had this happen last night and came here
searching for answers. It did not unloosen on it's own
after being left overnight. Finally this morning I came up
with something that worked for me. Shoot the lid all
around with a hairdryer and use a towel to keep seeing if
it has loosened up enough to move. After a few miuntes of
spraying it with the heat it stared sliding around and then
came up.
Jenn-Air JED8430... | Answered on Mar 02, 2019
hello, this unit does not have a fuse or thermostat to shut it down. it has to be the house breaker or wiring.
Jenn-Air JED8430... | Answered on Feb 21, 2019
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Jenn-Air JED8430... | Answered on Oct 20, 2018
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Jenn-Air JED8430... | Answered on Sep 27, 2018
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Jenn-Air JED8430... | Answered on Oct 02, 2017
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
Jenn-Air JED8430... | Answered on May 04, 2017
For free help and parts the best website for this type of home appliance is at the link below.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jenn-Air JED8430... | Answered on May 03, 2017
I had no instructions, manual, no receipt at all, due to a residential move. I asked questions and described the product numerous times - even went to Office Max to ask for any advice, describing what the Router action was and what was different. They gave me a list of possible Router Companies. This led me back to several phone calls, which did finally help. Guess what - part of the problem was with new techniques at my "Online Provider."
Jenn-Air JED8430... | Answered on Mar 08, 2016
You probably need to replace it. They are though fairly expensive. A little under $200 to be exact. http://www.partstore.com/ModelSearch.aspx?MfgName=Maytag&BrandName=JennAir&CloselyRelatedModels=true&ModelNumber=JED8430&x=41&y=30
Jenn-Air JED8430... | Answered on May 22, 2015
Ok Hello there.
Number 1)
There are several types of this 8430 but all will be similar . For the complete set of machines if you REALLY need the EXACT one.go here http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JED8430&siteCd=JA_EN_US&userType=Servicer#installation_instructions
Number 2)
PLEASE don't 'fiddle about' with the cooker if you don't know about electrics. There are VERY high powerand DANGEROUS electric cables in there ! This is Nothing like a low power Stereo or TV BE CAREFUL !!!!
Number 3)
I am not familiar with this top but it seems from the diagrams that it just drops in to a base unit that contains the fan unit.somehow. I don't see any screws in the surface of the top so TURN OFF THE POWER COMPLETELY take out by lifting the edges ; the whole thing and work on it from underneath to access the electrics..
These diagrams below will show you all you need to do the job. READ THEM THOROUGHLY BEFORE you start.
PLEASE BE CAREFUL with Electrical wiring. !!! I cant stress enough
Owners Guide
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208111P415-60.pdf
Parts list and circuit diagram (if your switch is playing up.this will help)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JED8430ADB.pdf
Installation
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P419-60.pdf
Jenn-Air JED8430... | Answered on Sep 20, 2014
To Unlock Cooktop: Touch and hold CONTROL LOCK for
5 seconds.
Jenn-Air JED8430... | Answered on Jul 14, 2014
Jenn-Air JED8430 Electric Cooktop Logo
356 questions posted
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
broken glass cook top
  • Cooktops
