Jenn-Air Refrigerators • Uploaded on Sep 12, 2013
Click here=>
Whirlpool's Ice Maker Harvest Cycle most of the information you are looking for is on the page above. I will let you begin by going to that link and saving the Whirlpool Ice Maker Troubleshooting PDF. Once you read over that material and are able to use an ohm meter we will move to the test points behind the ice makers front cover. Ice Maker have about a five year average life cycle and many times it is more cost effective if you replace the=> D7824706Q Ice Maker Assembly or click here=> D7824706Q Ice Maker Assembly In the clip below you basically have all the solutions in this one You-Tube Movie=> Ice Maker Repair I believe this is one of the better Whirlpool Ice Maker related video's and covers most all of what you need answered. I will be here to answer any questions. Checking the ice maker mold heater by testing the L and H test points (should show about 72 ohms of resistance) Testing the Ice Maker Timer L and M test points should show around 4400 ohms of resistance Motor You also can answer from the ice maker by testing just what condition your water control valve coil windings are by placing the test probes in the N and V test points where you should get between 150 and 350 ohms of resistance. I will be here to answer any questions you may have, If this solution is helpful please rate my solution, Thanks Sea Breeze
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start RelayRefrigerator or Freezer not Cooling or Getting Coldheatman101
39 questions posted
533 Questions
124 Questions
117 Questions
98 Questions
81 Questions
