20 Most Recent
Hotpoint HSH22IFT Side by Side Refrigerator Questions & Answers
My Hotpoint refrigerator drips water some times
In most refrigerators there is a drip pan underneath that captures condensation and allows it to evaporate. Possibly your drip pan is missing or improperly installed so that the condensation is dripping onto the floor. Check your manual, or find one online. Usually you just have to remove the grill from the bottom of the fridge to get access to the drip pan.
11/19/2017 11:23:58 PM •
Hotpoint...
Answered
on Nov 19, 2017
Freon type? R-12 or 134A?
Ever since about 1995 everything has been 134A....so I'm quite sure yours is too...
heatman101
11/23/2010 5:42:44 AM •
Hotpoint...
Answered
on Nov 23, 2010
My hotpoint sidebyside freezer are isn't working
Remove the control board and check the back for burn spots. If it appear good it probably is. Replace if burnt or soldier burnt pin back to board or replace. If good, jump the line terminal and defrost terminal(bottom left of board) with an insulated jumper you can see the defrost heater glow red hot at vents in the freezer bottom.
3/28/2009 3:57:42 PM •
Hotpoint...
Answered
on Mar 28, 2009
Refrigerator is not cold
Is there frost in the back panel of the freezer section? Is there air being blown from the freezer side to the refrigerator side? Do you hear the freezer fan running? I have some tips you can check out first then you may need a tech out if they don't help. There could be a problem in the defrost system restricting air flow, a problem with the damper door stuck closed not allowing air to move to the refrigerator side or a problem with the compressor. Best of luck!
http://tclaundryrepair.com/refrigerator
3/2/2009 11:09:12 PM •
Hotpoint...
Answered
on Mar 02, 2009
Problem with drawer configuration. I have a Hotpoint Freezer. Model FZA84.
Does the problem move with the drawer when you shuffled them or did it do the same thing in the same position? If it moved it's the drawer causing the issue, if it stayed in the same place it's the freezer itself.
Empty the offending drawer and have a good look at it. A lot of front panels on freezer drawers are a 'push on' fit so check the front is clipped on correctly on both sides. Next check the runner rails and back panel of the area that drawer goes into. It might be something as simple as a lump of ice or something stuck to the side/back or a something in the drawer above or below blocking it.
6/28/2023 5:17:16 PM •
Hotpoint...
Answered
on Jun 28, 2023
I heard some clicking noises
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
5/17/2023 6:40:48 AM •
Hotpoint...
Answered
on May 17, 2023
Can you disconnect the ice maker only on a hotpoint ctx21ga refrigerater
Yes, you can disconnect the ice maker on a Hotpoint CTX21GA refrigerator. Here are the general steps to follow:
- Unplug the refrigerator from the electrical outlet or turn off the power at the circuit breaker.
- Locate the water supply line that runs from the back of the refrigerator to the ice maker. It is typically a flexible plastic or copper tube.
- Find the valve where the water supply line connects to the refrigerator. It may be located behind a panel or cover.
- Turn off the water supply to the refrigerator by closing the valve. You may need to turn it clockwise to shut it off.
- Disconnect the water supply line from the valve by loosening the compression nut or other connector.
- Locate the ice maker inside the freezer compartment. It is usually mounted on the back wall or ceiling.
- Unplug the ice maker's electrical connector by pulling it out of the socket.
- Remove any screws or mounting brackets that hold the ice maker in place and gently pull it out of the freezer compartment.
- If you wish to permanently remove the ice maker, you can disconnect the wiring harness and remove the mounting bracket.
- If you plan to reconnect the ice maker in the future, you can leave the wiring harness connected and store the ice maker in a safe place.
- Reconnect the water supply line to the valve and turn the water supply back on.
- Plug the refrigerator back in or turn the power back on at the circuit breaker.
2/21/2023 12:04:57 PM •
Hotpoint...
Answered
on Feb 21, 2023
How to change the fast freeze flap on a hotpoint HUZ 1221
- Remove any food or items from the freezer compartment.
- Locate the fast freeze flap at the back of the freezer compartment. This is usually a small plastic or metal door that can be opened and closed.
- Use a Phillips head screwdriver to remove the screws or clips that secure the fast freeze flap in place.
- Carefully lift the fast freeze flap off of its hinges and set it aside.
- Take the new fast freeze flap and place it in the same position as the old one, making sure the hinges are aligned properly.
- Secure the new fast freeze flap in place using the screws or clips that you removed earlier.
- Close the freezer compartment door and return any food or items to the freezer.
1/3/2023 11:30:25 PM •
Hotpoint...
Answered
on Jan 03, 2023
