20 Most Recent Jenn-Air JFC2089HE French Door Refrigerator Questions & Answers
I have a Jenn-air JFC2089HPR Refrigerator. The
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
7/22/2018 6:40:03 PM • Jenn-Air... • Answered on Jul 22, 2018
Ice is still being made but water dispenser is not working? How do i fix this and where is it located for the problem?
could be you dispenser water solonoid valve, its on top, back of fridge behind panel
12/31/2015 1:20:32 AM • Jenn-Air... • Answered on Dec 31, 2015
Whiney buzzy noise
Could be a fan needs oil or replacing. Find a fan outside and a fan inside.
5/27/2015 7:35:35 AM • Jenn-Air... • Answered on May 27, 2015
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
3/21/2015 8:36:09 PM • Jenn-Air... • Answered on Mar 21, 2015
Runs much longer now than it use to, any suggestions
DURING Summer time you will find fridges run longer. When the last time you had the condensor cleaned. Pull the fridge our and remove rear cover at the base. Make sure your fridge is unplugged. Use a brush and vacuum to clean the lint. watch for condensor motor and clean between coils.
8/21/2014 1:34:27 AM • Jenn-Air... • Answered on Aug 21, 2014
2answers
How to correct/ adjust open freezer drawer that will not close?
check if anything is in the way
8/21/2014 1:16:44 AM • Jenn-Air... • Answered on Aug 21, 2014
0answers
0answers
0answers
Jenn Air JFC2089HES Frig and Freezer not working.
Up is up and down is down...... What numbers is it changing back to? If you hear a fan that is good. Do you hear any 'clicking' by chance? It is possible that for this, you may have a bad thermistor, but more information and or possibly an error code would help much more.
5/5/2014 6:16:09 PM • Jenn-Air... • Answered on May 05, 2014
Frozen food in refrigerator
Can you confirm your model number? I see what says that your model is a JFC2089HE above your post but knowing Fixya the model number there is automatically placed there and is most times incorrect, Thanks John Tripp Appliance 911
2/21/2014 1:21:22 PM • Jenn-Air... • Answered on Feb 21, 2014
0answers
0answers
Reset switch
No. You should look at the start capacitor and the overload switch on the compressor. The defrost timer may have it shut off too.
1/17/2014 4:21:02 AM • Jenn-Air... • Answered on Jan 17, 2014
Jenn-Air JFC2089HE French Door Refrigerator Logo
162 questions posted
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Refrigerators
Most Popular Question
correct adjust open freezer drawer will
  • Refrigerators
