20 Most Recent APC Smart-UPS SC 1500VA UPS System Questions & Answers
2answers
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power. Note: Ifthe power disturbance is brief, you may only hear one or two beeps. 2. Continuous Beeping (On Battery LED will beilluminated)This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.4. Continuous Two-Tone BeepThis alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down. 5. Continuous Tone (On Battery LED will beflashing)This alarm indicates that the battery-poweredoutlets are overloaded.6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLYThis alarm indicates that an internal UPS faulthas occurred.
12/9/2014 7:51:00 PM • APC Smart-UPS SC... • Answered on Dec 09, 2014
Service manual
This unit may still have a factory warranty, what's the first 2 numbers after the letters on the serial number? This will tell you the year of it and if it's 2012 or 2013 then you have a warranty still.If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
11/5/2013 10:14:53 PM • APC Smart-UPS SC... • Answered on Nov 05, 2013
UPS battery is over heating while plug in, and
The battery in UPS supplies a dc vcoltage to an converter which in turn converts the dc into acceptable ac voltage. When a load is connected to output terminals of UPS, a certain amount of current is drawn which in turn to be supplied by battery to the converter circuit. When the current flows through the battery, due to its own internal resistance heat is generated in battery that causes heating up of battery. When there is no load to ups, but charging of battery is on, the charging current passing througfh the internal resistance of battery heats it up. so either charging or discharging time the battery gets heated up. Ripple is sometime expressed as millivolts to per output volts. insuch cases the ripple has to be multiplied by output voltasge to get the correct value. Ripple content can be measured using fast responding sensors connected to the system or oscilloscopes.
5/2/2013 2:10:40 PM • APC Smart-UPS SC... • Answered on May 02, 2013
2answers
How to replace an apc battery back up battery
Depend on model. For 600VA and above Go to APC site and check model of replacement battery. Peel open the front plastic panel and unscrew 2 screws of metal panel. Batteries can be slid out and replacement done when PC is online. Only two wires to disconnect and connect.
3/20/2024 8:29:54 AM • APC Computers &... • Answered on Mar 20, 2024
APC USB2HUB-7P-1V. What is the correct power supply for a usb2hub-7p-1v please?
There is no data on it, just a picture on Amazon India. Contact APC or Newegg direct. Look at the label on the rear of the hub as it may have the input voltage https://www.google.com/search?q=apc+usb2hub-7p-1v+replacement+power+supply ..
2/25/2024 6:58:58 PM • APC Computers &... • Answered on Feb 25, 2024
UPS BE500R-PH microcontroller pic16f716
6/8/2023 7:35:42 AM • APC Computers &... • Answered on Jun 08, 2023
HELP! See details please
I would replace batteries, they do not have a long life. beeping The Back-UPS product has entered a low battery condition - This alarm indicates that the UPS has reached a Low Battery condition and will soon shutdown. The UPS can only operate on battery for a limited amount of time. clicking copy and paste link https://www.apc.com/us/en/faqs/FA158813/
5/26/2023 1:53:51 PM • APC Computers &... • Answered on May 26, 2023
What is APC Event 255? It is beeping occasionally but not continuously.
It means it was Event number 255 and the next one will be Event 266. You can read them on the computer is is connected to. If the beeping is annoying, you can reset it. https://www.apc.com/us/en/faqs/FA156611/#__highlight
2/15/2023 7:28:00 PM • APC Computers &... • Answered on Feb 15, 2023
Where can I get transistor GP4063D/ IR 214 for APC UPS IS1244003099
You can purchase electronic components, such as the GP4063D/IR214 transistor, from various electronic component distributors such as Mouser, Digi-Key, Arrow Electronics, and more. You can also check with local electronics retailers or online marketplaces such as Amazon or eBay. It is best to check the availability of the specific component with multiple suppliers to ensure that you can get the component you need in a timely manner.
2/1/2023 6:08:59 AM • APC Computers &... • Answered on Feb 01, 2023
2answers
I need to know where the serial number and model # is located on my APC mini chopper
you to www.apc.com, choose the country you are in, go to product and services, choose the model you have than check what ever you need for the product you have chosen, good luck
8/11/2022 7:22:25 PM • APC Computers &... • Answered on Aug 11, 2022
2answers
APC BK650EI 650 VA 400 Watts (1) IEC 320 C13 (Surge Protection) (3) IEC 320 C13 (Battery Backup) Outlets Back-UPS CS 650 USB/Serial. It blinks random orange LED.
I say yes he manual shows ,setting sensitivity here. the sound like charger fail. Inside. inverter works, did you let it charge overnight first. and disable the beeper if annoying. is AC line voltage low? that too can beep. is this USA model 120vac or outside USA> also if the UPS is for another country that will be bad. 650EI , is not the E means European version"??? why skip country. >? and matters huge that. EI is 230vac version, and will be wrong used in 240vac countries and worse. yellow led only blink is low line AC as the manual tells my guess you bought the wrong UPS?> v2 docs but not told version page 2. https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG_990-9237_EN&p_enDocType=Quick+start+guide&p_File_Name=BU+UM+990-9237B+MN01+EN.pdf
6/20/2022 2:52:04 AM • APC Computers &... • Answered on Jun 20, 2022
Hello, I am looking for a schematic diagram for APC 650 BK650 MC. Does any one have it? Thank you.
none officiallysome rare versions leak out, try googling for leaks there is no other way to find leaks, (confidential docs)
5/29/2022 11:13:13 PM • APC Computers &... • Answered on May 29, 2022
My power supply APC UPS-ES 700 won't power on ,at all .
APC.com have many here. there are fuses inside that blow too. not just the rear breaker. fails with NO Loads cables connected at all? 1: batteries shorted or dead. short overload it . there is a battery fuse, easy or hard to find ,easy on my loved smt750C. the true model of you UPS is not front stamps but the rear label tells the truth. 2: turn it on with not batteries yet, some turn on with error light or on mine LCD hard text errors,. no bats. 3: that is about it besides bad PCB. ES-700 those pan-cake UPS. sure. batteries do fail for sure out of the blue. (plates inside can short) out of the blue. or one cell goes dry and open and dead. the battery fresh pulled will read 13.0vdc. (good UPS) not 10 not 1, not 0 13. or 12.8v min. rested 5 hours post charged. the brain inside (firmware) is not very smart. it see's any errors it does not like and turns off fast. blink of eye fast . it can. shorts , or battery seen shorted. or blows fuse, deep inside on PCB up to 400volts inside do not touch that with hands, lethal are you on 240vac? we are 120v here.
2/10/2022 12:31:15 PM • APC Computers &... • Answered on Feb 10, 2022
Why won't the new battery allow the xs go on line
let it charge overnight, (new real or new from ebay not new) never assume it is charged new. make sure rear AC circuit breaker on it is not tripped makes sure battery fuse not blown make sure battery lugs not rusty. learn how to bench charge any AGM battery like this at 3amps max, ? (AND ATV CHARGERS IS WOW HERE) 2004 UPS, many were recalled for not having fuse. on the battery feed. and cause smoke. why use 15-04 -11 year old UPS>? MOST THAT OLD HAVE BIG PROBLEMS.
2/6/2022 12:26:30 PM • APC Computers &... • Answered on Feb 06, 2022
OWNERS MANUAL FOR BR1500LCD
apc.com (step 1 tell them your country first, seems you did not.) most easy question on earth . and answered. in usa most APC were banned in jan 2022, a horror here, most discontinued are still supported with manual and software. not deleted. for even 10 or more years.(found it) i can not decode your model (i guess BR is the code) on the rear or side off UPS is a white sticker or service tag for sure and you did that I see. and on such tag is the real model number even encoded for country . and your unstated countries voltage line input. APC BACK-UPS RS BR1500LCD 1500VA/865W UPS System(2006 made) are you in barbados posted to N.Amercias'/ if yes learn to only go to APC site for your country of find nothing you will..... seems not sold in many countries but is old. https://download.schneider-electric.com/files?p_File_Name=ASTE-6Z7VAU_R0_EN.pdf&p_Doc_Ref=SPD_ASTE-6Z7VAU_EN&p_enDocType=Quick+start+guide
2/5/2022 6:55:23 PM • APC Computers &... • Answered on Feb 05, 2022
APC BACK- UPS ES 500 IS NOT SWITCHING ON !
the batteries are bad now. for sure parked like that. kills themn.
2/5/2022 3:55:12 PM • APC Computers &... • Answered on Feb 05, 2022
Model 420 Pro. Why is output only 84 VAC?
no real model told , off rear sticker, (tell sticker model first) 420va no country told no line voltage told in your country Did you buy the ups from wrong country(oops) and it has higher input voltage spec and yours is lower input? (real) nobody can guess what's up there. history and all that and location, voltages are not the same word wide at all nor frequency 50/60Hz did you buy a used UPS. if yes from where ebay, and from wrong country or it ran for years and fails now. or outputs overloaded on it.
2/5/2022 3:47:12 PM • APC Computers &... • Answered on Feb 05, 2022
I have a APC BR600CI-IN ups.its battery not getting charged then i installed a new battery.but create same problem after 2 days.i need to know which component is bad.ic TNY 275 pn?
international model (i) in Europe are you speaking english./? the main board is bad apc does not sell:
  • spare boards
  • nor schematics
  • nor BOM (bills of materials)
they do have service contracts out of warranty .$$$$$
  1. buy new one. whole
  2. buy used one good.
are 2 choices.
2/5/2022 3:29:39 PM • APC Computers &... • Answered on Feb 05, 2022
APC Smart-UPS SC 1500VA UPS System Logo
8 questions posted
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • APC Computers & Internet
Most Popular Question
error light in apc smart ups sc 1500va
  • Computers & Internet
