20 Most Recent
Hampton Bay AC434-WB 52'' Ponte Vecchio Weathered Bronze Ceiling Fan Questions & Answers
Connecting wires
You are just missing one wire to all the circuits. The ones that work are good ... add the one wire that is not hooking up to the others to complete a serial circuit.
Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
What kind of saf tbar and bracket for hampton bay 52 inch ceiling fan
Hampton Bay Ceiling Fans typically use a universal mounting system, which is compatible with most ceiling fan down rods and mounting brackets. If you have a 52 inch Hampton Bay Ceiling fan, you can use any standard mounting bracket and support bar (also known as a "J-Hook" or "Safety T-Bar") that is rated for ceiling fans up to the same weight and size. The weight of your specific fan should be listed in the product manual or on the manufacturer's website.
It's always a good idea to double-check the compatibility of any mounting hardware with your fan before purchasing, to ensure that it will provide a secure and stable installation.
